Losi Jr. T (eBay bargain)
LosiXXkid
Re: Losi Jr T (eBay bargain)
Post by LosiXXkid »
It'll be Friday tomorrow and it still hasn't arrived.... :( ....this isn't looking great at the moment.
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
LosiXXkid
Post by LosiXXkid »
Friday's post has been and gone......and still nothing........ :?
Grrrrr! :x
Time to involve eBay me thinks.
DHC6
Post by DHC6 »
Where is it coming from? Looks like it's only been 10 days stince you won the auction. When was it posted? I have waited up to a month for parts to arrive from forign countries. So 10 days isn't very much.
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return - Leonardo da Vinci
LosiXXkid
Post by LosiXXkid »
DHC6 wrote:Where is it coming from? Looks like it's only been 10 days stince you won the auction. When was it posted? I have waited up to a month for parts to arrive from forign countries. So 10 days isn't very much.
It's coming from Paris, France (...hopefully).
However, it's not necessarily the amount of time it's taking, this is more about poor communication on behalf of the seller. I've e-mailed him a few times already and the truck has been shipped on at least two occasions.... :lol: .....most recently by his wife........who then didn't actually post it!
He seems genuine enough and I'm sure he is but the whole experience is proving to be a bit crap!
LosiXXkid
Post by LosiXXkid »
OK, good news! It finally arrived..... :D .....photo's to follow.
DerbyDan
Post by DerbyDan »
Wooot! :D
Good things come to those who wait :wink:
LosiXXkid
Post by LosiXXkid »
So here we are at last, some photo's.....
40 Euro's worth of Junior T! Did I say bargain....? :D
Contents of 'the big brown box'.
Losi Jr. T 007c.jpg (114.91 KiB) Viewed 937 times
Tyres are in good shape. Fronts aren't glued while the rears have only been glued on the outside bead....not a great job though.
Wheels & tyres....
Losi Jr. T 010c.jpg (122.97 KiB) Viewed 937 times
Wheels & tyres....
Wheels & tyres....
At first sight everything looks good, however, on closer inspection there are a few issue's that need 'fixing'. This also looks to be a bit of a 'bitsa' truck which hasn't been put together very well and it also has a mixture of old and new parts.
Chassis.
Losi Jr. T 011c.jpg (123.83 KiB) Viewed 936 times
Chassis.
Chassis.
There are a few scuffs and scrapes to the chassis but no visible wear marks to the RPM suspension arms.
Underside.
Losi Jr. T 012c.jpg (118.09 KiB) Viewed 936 times
Underside.
Underside.
Front end with the JG Mfg body mount.....although it quite clearly isn't complete.
Front end.
Losi Jr. T 013c.jpg (110.59 KiB) Viewed 936 times
Front end.
Front end.
Rear Pro SE shock tower is actually higher than the rear body mount which isn't much use.... :lol: ...so a new rear body mount is on its way!
Rear.
Losi Jr. T 014c.jpg (121.3 KiB) Viewed 936 times
Rear.
Rear.
LosiXXkid
Post by LosiXXkid »
Asso_man! wrote:You have a set of nice and rare MIP hard teflon coated shocks there!
Errr! No I don't.... :(
As you can see from the above photo's the MIP shocks were obviously removed and replaced with some later Losi shocks. I'm not actually that bothered although it would have been nice......
LosiXXkid
Post by LosiXXkid »
A few more photo's....
The motor plate shows sign of wear on the outside but there's no evidence that a motor was actually fitted... :?
Rear RPM 'Truck' arms.
Losi Jr. T 016c.jpg (119.49 KiB) Viewed 935 times
Plastic bushings in the rear hubs.....same goes for the front wheels.
RPM Rear hubs.
Losi Jr. T 020c.jpg (111.81 KiB) Viewed 935 times
RPM Rear hubs.
RPM Rear hubs.
RPM Wide front arms look brand new and there are no marks to the JG body mount.
Front underside.
Losi Jr. T 017c.jpg (122.55 KiB) Viewed 935 times
Front underside.
Front underside.
RPM Chassis brace also looks new but is attached with some slot-head screws, the ones in the rear being too short to hold it in place. Also, I'm a bit confused about the bit of chassis that's missing....odd!
Steering arms...
Losi Jr. T 018c.jpg (116.16 KiB) Viewed 935 times
Steering arms...
Steering arms...
The rear tie-rod ball studs are pushing the shock tower out at the bottom and is only held in place by the two centre screws.
Badly attached rear shock tower.
Losi Jr. T 021c.jpg (110.02 KiB) Viewed 931 times
The L/H side of the transmission case is cracked slightly which I know is quite common. The diff definitely needs attention as does the entire gear box as it feels very loose.......but no visible signs of a motor ever being fitted. :shock:
Transmission.
Losi Jr. T 024c.jpg (108.76 KiB) Viewed 931 times
Transmission.
Transmission.
jamin
Been thanked: 28 times
Post by jamin »
Looks pretty mint from the pics, good find I'd say!
LosiXXkid
Post by LosiXXkid »
jamin wrote:Looks pretty mint from the pics, good find I'd say!
Most of it is but the tie-rod ends have been chewed up with pliers.... :x ....I hate pliers!
LosiXXkid
Post by LosiXXkid »
And a few more....
Here's the issue with the Pro SE shock tower and the rear body mount. The shock tower looks new so my guess is that it was put on to replace the standard Junior 2/T plastic version.
Shock tower / rear body mount side view.
Losi Jr. T 026c.jpg (109.38 KiB) Viewed 930 times
Shock tower / rear body mount.
Losi Jr. T 050c.jpg (97.89 KiB) Viewed 930 times
Minimal wear on the tyres, particularly the rears.
Tyres...
Losi Jr. T 053c.jpg (113.13 KiB) Viewed 929 times
Tyres...
Tyres...
That missing bit of the chassis...
Odd???
Losi Jr. T 045c.jpg (107.36 KiB) Viewed 928 times
Odd???
Odd???
The RPM rear hubs. Very happy to have got these as I've never seen them before..... :D
RPM Rear hubs.
Losi Jr. T 049c.jpg (113.66 KiB) Viewed 928 times
RPM Rear hubs.
RPM Rear hubs.
JG MFg front skid plate / body mount. The underside of the top holes are countersunk but what about the body posts themselves? They weren't included so what would have been used? Any ideas?
JG Mfg skid plate / body mount.
Losi Jr. T 057c.jpg (120.95 KiB) Viewed 921 times
Right, that should do it in terms of 'before' photo's so it's time to tear it down and start the rebuild.
Now the fun begins! :mrgreen:
alien3t
Post by alien3t »
http://www.ebay.com/itm/Vintage-Losi-JRX2-Pro-Pro-SE-LXT-A-2024-REAR-SHOCK-TOWER-SPACER-NIB-New-/181566519449?pt=Radio_Control_Parts_Accessories&hash=item2a46353899
part of why the tower isnt sitting right is that on the pro se and lxt with that bulkhead and that thin shock tower, this spacer goes between. might set it right with its distance from ball stud also, if the ball stud is the correct length.
LosiXXkid
Post by LosiXXkid »
alien3t wrote:http://www.ebay.com/itm/Vintage-Losi-JRX2-Pro-Pro-SE-LXT-A-2024-REAR-SHOCK-TOWER-SPACER-NIB-New-/181566519449?pt=Radio_Control_Parts_Accessories&hash=item2a46353899
Thanks! I've got a couple of those so I will fit one during the re-build and yes, you're correct in that the spacer should fix the problem. :) The ball stud looks to be 3/8" so it should be correct.
Return to “Losi Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
