Tomas TRX-1 Vintage race machine:)
Tomas Karlsson
Re: Tomas TRX-1 Vintage race machine:)
Post by Tomas Karlsson »
Thanks for the inputs.
The gears that are used for the A&L slipper is Robinson but where can i order them?
TRX-1-3
Has thanked: 2068 times
Been thanked: 992 times
Post by TRX-1-3 »
Seabass
Business Member
Post by Seabass »
Tomas Karlsson wrote:Thanks for the replies guys.
Can anyone tell me if i can put on another slipper so i can use gears from modern cars etc?
Buy this
http://www.teamstrc.com/index.php?route=product/product&product_id=661
It drops right into your TRX1 tranny and uses the Associated slipper parts, pads and gears. You will need to remove your idler gear from the factory top shaft and install on this. Very nice product and well worth the money. Will give your TRX1 a proper slipper. You could even use the VTS slipper if you wanted as well.
Jake
Tomas Karlsson
seabass, i bought it, thats perfect and pretty cheap also. I have an RC10 i can steal the slipper from:)
Tomas Karlsson
TRX-1-3
Post by TRX-1-3 »
That buggy is looking nice. How is the body fit? You mentioned it was a TBG repro, yeah? I'm always looking for another TRX-1 body.
Thanks
Mark
Tomas Karlsson
I think the body is great and now u can use your esc on the chassi instead of the rear tower. TBG has this one and the original shaped TRX1 body to choose from.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
Cool TRX1 :) that's the TBG S&K repop, right? It looks good, actually :)
And I second Seabass here - being able to use a modern B4 slipper on the TRX1 is great, because the stock slipper is, let's face it, very suboptimal...
Keep it up and shoot videos of it when done!
Paul
Tomas Karlsson
And now with som decals, i will switch the wing and add the big blue Traxxas sticker on it.
rctenracer
Been thanked: 81 times
Post by rctenracer »
Tomas Karlsson wrote:Looking for an upgrade, i have ordered some stuff yesterday that will be good for this project.
Can anyone tell me where i can find 2.2" wheels for this car?
Here´s an ugly pic on the ride so far...
For some reason I can't get the link up . jcracing has traxxas five spokes 2.2 that will bolt on with no mods.
Tomas Karlsson
Hi, it would be awesome if you can find the link for the wheels, very much appreciated.
Is there anyone that know anything about drive shaft compability, replacements from newer cars etc? mine is pretty worn so i need to replace them soon.
you can still get traxxas universal joint sliders, they haven't changed. the axles you may have to find a trx1 style on ebay or the like, maybe bandit axles? the other thing you can do, if you want to make a set pretty bulleproof is to take a 5mm axle that is longer from some vehicle, and add those metal u-joint drive cups like you would use on the trans outputs, so in effect, you have metal yokes at both ends. I never stripped the plastic off the stock axles, but maybe just need to remove the plastic yoke and the stock axle would be good to use?
they are around, have to check the international shipping:
http://www.ebay.com/itm/HARD-TO-FIND-Traxxas-2753-Rear-Stub-Axles-TRA2753-NEW-IN-PACKAGE-/281091123778
this is jc racing link, just click through to jcracing>>wheels>>1/10 off road>>traxxas 5 spoke
http://www.jcracingproducts.co.uk/products/
TRX-1-3
Post by TRX-1-3 »
5 mm axle no hex rears and 5x11 bearing fronts? With the wheels. Has anyone ordered these?
Mark
Tomas Karlsson
jwscab,
Thanks again! The stub axle you linked has an horrific shipping quote to Europe. 24USD. Well i can try the 2753X axles instead to see if they fit.
Need to test this car soon to se if it will hold up.
after posting that link, and looking around, those are readily available in many places, as it was used on a bunch of traxxas vehicles. so you should be able to find a set with more reasonable shipping, for sure.
Return to “Traxxas Forum”
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot] and 5 guests
