94 yz-10 with options!
Re: 94 yz-10 with options!
Steering is like the works 93.. way better than the wire setup.. looks great so far.. I need to get off my butt and get to finding and making some stuff.. great motivation here..
Shawn
Shawn
- stickboy007
- Been thanked: 20 times
That steering setup is an optional steering brace/rack that was offered for the '94. The full "kit" for this optional steering rack included a taller post to go on the right hand side, to connect to the top brace. The bottom piece changes the steering geometry a bit. Some combination of ackerman and bump steer, since the inner ball stud is pushed both outwards, forwards, and downwards. If you add spacers under the ball stud, such that it is only pushed outwards and forwards by the bottom piece, then the net effect should be more bump steer (high speed mid-corner steering) and less ackerman (less initial turn-in). I'd have to study mine more closely to be sure, though.
Lipo trays for 94,95, Pavidis? No grinding of posts, no drilling new holes, no shoe goo, no glue. Just mount in stock location, no worries. Click the pic for the photobucket.
Very nice!! I love the set up of the lipo trays.. You're getting pretty good at this aren't you?? But really, love the design of these.. You do make some nice parts.. Love the parts I got from you..
Shawn
Shawn
Thanks. I do enjoy making parts and hope the end users enjoy them as much. Pm me or search ebay. I've got a set listed.
I just got another 1 of these 94 style buggies. I'm pretty sure its a genuine Wcs or Pavidis edition. Will post pics soon. Its got machined arms and the wcs cutout chassis. What else should it have?
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
In very short - the 93 WCS has kickup chassis 2X3 battery slots, aligned, "94" front end and machined/cutdown aluminum rear end with old style diffcap. Consider Yourself very lucky if it´s a WCS.
The 95 WCS and "Pavidis" is the same car, unless You´re talking about replicating the actual buggy Pavidis drove.
Member Dual, has constructed a timeline which can be found as a sticky (top section) in the Yokomo section.
Gone fishing
Heres some kinda bad pics. Just enough time this morning to show the arms and chassis. This buggy uses the 94 style plastic bulk heads front and back.
I havent taken it completely apart yet. Cant tell right off about the arms. They may be molded with the cut outs, or machined. No sli[pper clutch, but it does have the hardened drive pullies.
Top deck does have provosion for an adjusting turnbuckle in back. Does have the carbon camber brace plate in back. Wheels are black, 4 holes for screw retention.
Im pretty sure this one will not need any new parts, and possibly only a couple small bits from the other 94 in this collection. Of course, it will be shelfer used,, so not mint or new,, but should shine up nicely. Dang, these models are pricey!
- DennisM
I think there´s a slipper on that layshaft? From outer to inner : spurgear mounted on the outer slipperplate with 2 small screws, then slipper pad/ friction pad, last the inner slipperplate/rearpulley
Yes it´s pricey - not many around. But compared to the price of a new team spec. 4wd buggy (Yoke, AE, Kyosho), it´s not that bad
Gone fishing
I do agree about the price being reasonable compared to top shelf new. The 22-4 has recently dropped what,, 200 bucks from intro price?
But anyway,,,, glad to have won this car. I bid based on the thought it had a slipper setup,, as the pics were unclear. So, the spur is a screw on variety, but the spur mount is unfortunately just a locked affair,, no slipper. On the other hand,, I was figuring it to be a standard 94,, but extremely pleased to see its a bit more!
- 22 Replies
- 3637 Views
Last post by mdutcher
- 1902 Views
Last post by oneyedog
- 2209 Views
Last post by scoobyvoodoo
- 26 Replies
- 1935 Views
- 29 Replies
- 6035 Views
Last post by jcwrks
- 710 Views
Last post by soniccj5
- 1410 Views
Last post by blubblood
- 972 Views
Last post by Irio - esos
