Cat xl / xls chassis
- LurkingCAT
- Has thanked: 202 times
- Been thanked: 271 times
Re: Cat xl / xls chassis
Home made are the words. Yes, why not a hybrid
That is if the chassis lines up properly. Have a good look at the shock bracket and especially the suspension bracket. If your suspension bracket is a bit off (it looks like it's not all there) your rear wheel geometry will suffer. Of course with those upper arms you have the possibility of adjusting the camber to compensate. But also the arms maybe worth checking with respect to toe in and caster. If everything is ok someone has done a good job!
On further inspection the rear shock towers do seem to be a bit suspect so I think I'm going to have to source one from somewhere anyone know if you can get a carbon fiber ones ? And as for the wishboans they look like they should line up pretty well but they do need new threds and cups. So it looks like I may have a base for a (hybrid shelfer). Any help or suggestion would be greatly recived
- LurkingCAT
Shock mount and suspension bracket in carbon for £8.15 from Fibre-lyte. http://www.fibre-lyte.co.uk/fl/cars/schumacher/catxls.html
- 531 Views
Last post by rwinter
- 4110 Views
Last post by Mad Racer
- 4093 Views
Last post by Eau Rouge
- 6363 Views
Last post by XLR8
- 1885 Views
Last post by Rich D
- 1343 Views
Last post by Jay Dub
- 3223 Views
Last post by GreenHell
- 1239 Views
Last post by Bormac
