Having nothing better to do last year and a 3S - 2000mah lipo with a DOA cell kicking around I decided to hack it up into a 2S and shove it in my RC10L for kicks.
It ran great with the old Novak Rooster ESC and when it got down to the voltage limit the car was almost not moving anyway.
I couldn't top it out as is.. a Pan with no body on 2s lipo with a hot motor. It would spin out if you tried for full throttle..
Hmm I have the Heading hold gyro.. Perhaps I'll break out the pan again soon.
brushed speedo with lipo battery
- Jools
- Has thanked: 6 times
Re: brushed speedo with lipo battery
Hobbycity have a cheap Brushed ESC, About A$12, 45A. So far mine has worked faultlessly (with lipos) - just fun running, not comp or pulling huge amps obviously. I'm going to order a couple more at that price.matt1ptkn wrote:I have been running lipos with most of my vintage brushed ESCs, however, just found out last night that not all of them will handle it.Anyway, I found out after some research that one of the ESCs is not rated for use with lipos. Hindsight - should have researched it first.
The other one I have had temperature trouble even while using NIMHs, so not a huge surprise, but still irritating. I figured just for setup and making sure everything worked, a lipo would work fine since none of my NiCds nor NIMHs were charged. Nope. Live and learn.
Are there any fairly inexpensive brushed ESCs that would be recommended for use with lipos? Also, will MSCs handle lipos? I run MSCs in a few vehicles and even used the stock one in my RC10 for a little while last summer, just for old time's sake. I figure the resistors would probably get hot enough to spontaneously combust then start a lipo fire.
I think the cutout voltage is set for lipos. But check yourself. I use a 3 dollar low voltage alarm too.
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
I scored a few lipo alarms from a member here, so I'm not too worried about the batteries. My concern was more the ESC. I've had too much practice burning them up over the years.
I'll check out those inexpensive ESCs you mention. For the time being, I found a couple XL-5s on eBay for a descent deal. Even got the awesome Titan 12T motors, too! Actually, I was glad to get them. They are currently the best, legal motors for my LHS's SCT class...
Matt
I used to use lipos with by brushed gear in Touring cars and never had a problem, as most brushed escs could do 7 or 8 cells packs, which is about 8.4 volts anyways
ed
ed
Hi, my name is Ed, and im a addict.
- 4843 Views
Last post by longboardnj
- 2071 Views
Last post by SoloGraphix
- 2032 Views
Last post by racerjohnbf
- 852 Views
Last post by amp_driven
- 2340 Views
Last post by RC10th
- 1085 Views
Last post by RCveteran
- 960 Views
Last post by uniquenamehere
- 2303 Views
Last post by Lou0151
