Looking for Composite Craft two-tier front suspension detail
- Has thanked: 36 times
- Been thanked: 1319 times
Re: Looking for Composite Craft two-tier front suspension de
i think jake's arms are like an 1/8" longer than the worlds/klein arms.
- JPAE07
Good info since I'd like to obtain a couple from cc to support the cause.
So Klien arms are correct.
Can Associated rear mounts be dremeled and adapted to work?
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
I would say no way!JPAE07 wrote:Can Associated rear mounts be dremeled and adapted to work?
Come and visit the stable
- Been thanked: 7 times
Can someone advise me in this: I found that the CC chassis does not really level out, the four posts and the front horizontal post are at different height, seems like it will take some brute force to 'torque down' the upper deck. (while I am more used to the Yokomo YZ series, which the upper decks are rather 'passively' fitted)
Is it just my cc chassis?? Any advice is appreciated.
Thanks in advance.
Thanks in advance.
Yes this is the same with my car. I spaced up the rear bulkhead to help fit the battery and level the top plate. I also added spacers to the posts. Ill post pics tonight or tomorrow
thanks, looking forward to see the photos of the spacers add-on
Here are a few pics. First a side shot. You can see it still rises toward the nose
Here is the flat fiberglass spacer under the RPM bulkhead. The RPM trans brace still looks to sit flat.
And lastly the spacers under the top deck
Thanks for the photos.
Interesting to see I am not the only one having this problem with my CC chassis.....
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
I wouldn't worry about it too much. Composite Craft knew what they were doing so I'm sure it's not a design flaw or something that needs to be fixed.
The CC Worlds chassis I had 20+ years ago was the same way and it didn't seem to stressing the thin top plate very much when it was screwed it down.
- 768 Views
Last post by Kcal
- 28 Replies
- 4774 Views
Last post by bearrickster
- 3225 Views
Last post by Harrylarry
- 2823 Views
Last post by carloco8
- 884 Views
Last post by asashaw
- 1500 Views
Last post by Synergy
- 1444 Views
Last post by Dr. Robotnik
- 3141 Views
Last post by GJW
