The best degreaser... Ever
Re: The best degreaser... Ever
Was it in a house fire or something?
If so, I wouldn't be surprised if all the plastic is heat damaged!
As far as I can tell, the only real salvageable stuff is nuts and bolts. It is not even a complete car, it is missing parts.
Sent from my iPad using Tapatalk
Almost all my posts will be edited because I know what I want to write, but my fingers always hit the wrong keys.
To be fair, even if the plastic is heat damaged (how else could the chassis get smoke damage?), I would still expect the chassis and metal parts to be salvageable at least. Soot cleans off.
Still, I'd be a little wary of that one.
- Been thanked: 5 times
Pretty sure that is just your standard wax and grease remover repackaged as a different product. That's what most of those grunge/tar/bug/whatever be-gone products are.You can probably save some money by just buying a quart of wax and grease remover.Typicray@rainmans wrote:
I have never had a better degreaser, it is the most powerful, yet delicate cleaner I have ever used.
- Halgar
- Has thanked: 139 times
- Been thanked: 172 times
Having repaired a few burn out homes in my time, even where there is smoke, there is heat in most cases. It's a really crappy pic, but that looks like more than soot on that car. It looks like it was burned and it's rusted. Granted, it's an aluminum chassis, so it isn't rust, but I wouldn't buy it without seeing it in person.85Edinger wrote:To be fair, even if the plastic is heat damaged (how else could the chassis get smoke damage?), I would still expect the chassis and metal parts to be salvageable at least. Soot cleans off.
Maybe, but I have used many products and nothing has worked this well. The great part about it is that it is a concentrate.justinspeed79 wrote:Pretty sure that is just your standard wax and grease remover repackaged as a different product. That's what most of those grunge/tar/bug/whatever be-gone products are.You can probably save some money by just buying a quart of wax and grease remover.Typicray@rainmans wrote:
- Been thanked: 325 times
How much did you pay for that 120 mL container, approximately?
Ya beat me too it
I think that it is cheaper at the motorcycle shops.
I guess I'll stick with WD-40. I used that to clean up all the oil & grease, including the chain, on a vintage 30-year-old 10-speed Norco bike that belonged to my father, that he wanted to sell...I sprayed it on, waited about 5 minutes, then used a brush in the dirtiest spots, and wiped up with rags. It looked like new after I was done. (I re-lubed the chain afterwards, of course.) Not to suggest this product isn't amazing, I'm sure it is...but I always factor in the cost/benefit ratio.
For sure! I am not saying wd 40 is a sub par product, it works very well. This stuff is a great application for getting a massive amount of grime and sticky stuff off a car.Coelacanth wrote:I guess I'll stick with WD-40. I used that to clean up all the oil & grease, including the chain, on a vintage 30-year-old 10-speed Norco bike that belonged to my father, that he wanted to sell...I sprayed it on, waited about 5 minutes, then used a brush in the dirtiest spots, and wiped up with rags. It looked like new after I was done. (I re-lubed the chain afterwards, of course.) Not to suggest this product isn't amazing, I'm sure it is...but I always factor in the cost/benefit ratio.
- THE H.P FREAK
Okay, I think you might have the best degreaser, that is definitely a great value at $7THE H.P FREAK wrote:HI!... For $7 I get this :
- klavy69
- Moderator
- Has thanked: 634 times
- Been thanked: 294 times
me too. Could never have too much of that stuff around. Worked for everything. Even took the chrome off hpi wheelsbadhoopty wrote:i miss the old castrol super clean.
