Delorean DMC 1:10 Scale Body?
myfordcnc
Re: Delorean DMC 1:10 Scale Body?
Post by myfordcnc »
ouch!
Lowgear
Has thanked: 121 times
Been thanked: 796 times
Post by Lowgear »
Phin wrote:Re-packaged Kyosho Super Alta. I can understand why that might be worth that much to a collector.
Wow, I've never seen a DeLorean Super Alta before. Never mind a NIB one. If it wasn't a BIN auction, it probably would have gone for more.
hugger19
Has thanked: 25 times
Been thanked: 143 times
Post by hugger19 »
orginal auction i think he was asking $600 and it didnt sell so he relisted it at $300.
myfordcnc
Post by myfordcnc »
To Make a Buck (And I mean the form in this case) all you need basically is to not have any undercut (negative Draft) Right? What about shrinkage to you have to account for that. I have never worked lexan besides just hacking it up.
teman
Been thanked: 6 times
Post by teman »
I'm no expert, but I've had some time to experiment :D As I understand it, you need draft to help eliminate webbing, it also helps the body pop off the buck. You might need some air channels in that buck to get a good detailed pull. Figure out where the body will mount and there's your channels.
Don't worry too much about it shrinking, that's really only a problem if you were to repro a body from an existing body where you're pouring plaster or whatever into it to make a buck.
-Kevin
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
myfordcnc wrote:To Make a Buck (And I mean the form in this case) all you need basically is to not have any undercut (negative Draft) Right? What about shrinkage to you have to account for that. I have never worked lexan besides just hacking it up.
If you want to get the body to be the right size, you do have to compensate for shrinkage of the lexan. Most of the shrinkage in back poured repro bodies is due to the original body shrinking when it comes off the mould, so the mould taken from the body is slightly smaller than the original, then the new body shrinks again when it cools.
If you want to make a replica to a specific size, you will want to add 0.7% to the dimensions, so for a 260mm wheelbase you want to make a pattern with a 262mm wheelbase to allow for the shrinkage.
You don't want any negative draft, otherwise you won't be able to pull it off the mould. There are ways around it, for example to get an undercut at the front you can make a multi-piece pattern so you can remove it in two or three parts.
Has thanked: 1130 times
Been thanked: 3920 times
Which is why some tamiya bodies show odd mould lines...three piece mould with wedge shaped center 8)
Sixtysixdeuce
Post by Sixtysixdeuce »
Would a 1/10 DeLorean come with a 1/10 bag of coke in the 1/10 glove box?
Only if the Feds put it there :mrgreen:
