96 traxxas bandit outfitted with sand pattle tires
Re: 96 traxxas bandit outfitted with sand pattle tires
Alright, the body is finished drying and the tires are mounted
Almost all my posts will be edited because I know what I want to write, but my fingers always hit the wrong keys.
Nice.
You should get a second set of rear wheels/tires, one more suited to general use.
The Rustler has potential. A Rustler with good electronics, STRC hinge pins, aluminum caster blocks, upgraded shocks, rear toe in, good tires, and some suspension tuning can be a fantastic all weather basher or even club racer. My Rustler is used all year round. It's fast and fun in all conditions, very durable, and wins races.
Ya, i found some street tires in a box. It works really well! The next upgrades I want to do are adding a slipper clutch and putting longer rear a arms on it.
Typicray@rainmans wrote:The kimborough spur fits nicely! The 550 motor fits as well with the help of a couple washers.
What did you need washers for? If it was for gear alignment, you just need to flip the pinion around. The Titan is the standard motor in the XL-5 Bandit. Should be no need for washers to make it work.
The Bandit is a fun and durable buggy. I agree with the others that you should have fun with it. There's really no vintage value because the buggy is still being produced today. Go beat the snot out of it!!!!!
How did you get the body to fit with the esc mounted to the chassis? I had to remove the heat sinks on mine.
He needed washers to make the ridiculous motor shaft clear his gear cover.
I suggest removing the washers and cutting the shaft.
85Edinger wrote:He needed washers to make the ridiculous motor shaft clear his gear cover.
It shouldn't hit the gear cover either way. The Rustler/Stampede/Bandit/Slash all have the same trans and gear cover and all come standard with that same motor.
When the Titan 550 came out, Traxxas introduced a new gear cover to clear the motor shaft.
- klavy69
- Moderator
- Has thanked: 634 times
- Been thanked: 294 times
Maybe not up to everyone's likings but you got a clean looking bandit there so don't let anyones opinion slow down your postings
[/quote]
you caught me! No it doesnt fit, but i didnt realize that until after I put it all together. I will just screw a lexan plate on behind the battery and mount it to that.
Thank you! And I am just happy everyone has an opinion to input.klavy69 wrote:Maybe not up to everyone's likings but you got a clean looking bandit there so don't let anyones opinion slow down your postings.
What you should do is turn the battery around so the leads are towards the front of the car, then get an esc plate. That way you'll have somewhere to put the ESC and your lipo will be secured on both ends like it should be.
Ya, the way the battery sits in there is a little shady right now. The esc plate will probably be my next purchase.
- Regular Member
Thanks bro, hopefully I can get you to do a build soon... Maybe a midwest ready rock racer...or a snow slinging stampede?TRD Driver wrote:That is one sweet looking bandit!
- Regular Member
I agree man, I should take advantage of having 3feet of snow out side.
- 544 Views
Last post by Turbobuick
- 1050 Views
Last post by harry697
- 30 Replies
- 3995 Views
Last post by BeastyShout
- 47 Replies
- 7739 Views
Last post by Jester_The_RC_Guy
- 1449 Views
Last post by Hcp22
- 1841 Views
Last post by JK Racing
- 857 Views
Last post by clhuke64
- 1923 Views
Last post by shagrat69
Users browsing this forum: DotNetDotCom.org [Bot] and 4 guests
