Trashing a ton of bearings
Re: Trashing a ton of bearings
Good to hear that it's not just me. I go through so many metal shielded 1/4 x 3/16 bearings.
- teman
- Been thanked: 6 times
I clean and lube bearings quite often, mainly due to the fact my test track gets super dusty and I run quite a bit. I've come to realize I blow much less bearings after I started the clean and lube regiment. I don't have an oil preference, it's usually what the LHS has on hand either Parma or CRC that I buy.Seabass wrote: What are you guys using for lube if any when rebuilding. I typically don't lube the bearings, just clean them off with a dry brush.
Parma T.Q. Bearing Oil PAR741 Calandra Racing Concepts SpinTech Bearing Oil CLN4060
-Kevin
- 372 Views
Last post by matthew john
- 667 Views
Last post by orangemazda
- 524 Views
Last post by FordPSD
- 712 Views
Last post by sneako43
- 626 Views
Last post by cherokee
- 1217 Views
Last post by tbfoto
- 1129 Views
Last post by andymac0035
- 1293 Views
Last post by naushad
