Removing old shoe goo?
- slotcarrod
- Been thanked: 45 times
Re: Removing old shoe goo?
Just peel it off, it's just a harder form of silicone glue.
Rod Littau
- Blacktiger355
Tried that, won't budge!slotcarrod wrote:Just peel it off, it's just a harder form of silicone glue.
- knixdad
- Been thanked: 4 times
I've been scraping a XXXS chassis for a week now, shoe goo was stubborn. Ended up peeling most of it. Now I'm dealing with the thick layer of CA that was under it. Acetone didn't faze either. Neither did Goo Gone or motor cleaner, WD40, PB Blaster and other nonsense I tried.
Best part? After peeling away the goo covering all the lead fishing weights and pulling off all the weights, I saw they had drilled tons of holes. Sometimes RC feels like archeology.
- Blacktiger355
- knixdad
I have 2 or 3 more XXXS chassis to work with. The XXXS/4 chassis is way stiff anyway. I think I will convert it to a rally, I was going to use a chassis protector to keep the dirt out of the battery slots, so the other holes will not be a big deal.
What I need is a 55 gallon drum of acetone to soak stuff in. That would be ideal.
- Been thanked: 325 times
I wonder if heating it up with a heat gun would help remove it? It shouldn't cause any harm to aluminum, graphite or carbon fiber....wonder if it would work.
- Blacktiger355
Sadly I do not have a heat gun. May need to hit up Harbor Freight and get a cheapy.
- knixdad
I have an "unfancy" DeWalt that has been excellent for me. Didn't try it on the Goo, since I was working with a composite chassis.
- Has thanked: 100 times
- Been thanked: 205 times
If the 'shoe goo' is too hard to peel up... it might not be shoe goo after all but a softer epoxy? Just a thought.
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- Blacktiger355
Hmm, maybe but it cuts pretty easy with a razor blade. What ever it is, getting it off will not be kind to the part. LOL
Sounds like a softer setting epoxy.
Chris
Chris
you can try 1:1 car carburetor cleaner, or various type of brake cleaner. One of those is a lovely concoction of a bunch of solvents, something in there would probably help break it down and I know it doesn't harm anodizing.
you can also try warming the part, over a toaster/oven, or stove top, or some other gentle heat source, then quickly take it outside and hit with some cleaner. the heat in the part might help release whatever it is.
- Blacktiger355
I know this is an older thread, but I've been using MEK (methyl ethyl Keytone) for years on circuit boards. It does not attack the laminated boards at all. It's a great cleaner you just need to respect how dangerous it is. I just received a world s chassis that was covered in Shoo goo. I think the previous owner liked to use it more than using hardware. I used the MEK on a rag and lightly wiped the Shoo goo and in 20 minutes I was done. No damage to the ano at all and there was no black residue on the rag when I was done. Hope this helps.
I'm not like them, but I can pretend...
- Blacktiger355
- 923 Views
Last post by suby56
- 733 Views
Last post by GJW
- 2039 Views
Last post by Winger
- 3091 Views
Last post by Vintagemishal
- 1838 Views
- 1472 Views
Last post by realoldschooldude
- 1264 Views
Last post by Jay Dub
- 515 Views
Last post by LTO_Dave
Users browsing this forum: Dustydrone,
juicedcoupe and 3 guests
