Blacktiger355's RC10 A and B stamp builds!
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: Blacktiger355's RC10 A stamp build!
and it begins...first just a car, then a spare chassis, then a roller to put parts on the spare chassis....then a truck & a b2, b3, team car, worlds car, edinger, cadillac, couple re-re's just in case, then an all white parts car, black parts car, dyed orange car...RPM ultramolded long arm car.
Great base to start a runner build off of...just messin' with you above. But watch out, its addictive.
- Blacktiger355
- JPAE07
Holy smokes, thought you were talking about me before I realized you were generalizing.JK Racing wrote:and it begins...first just a car, then a spare chassis, then a roller to put parts on the spare chassis....then a truck & a b2, b3, team car, worlds car, edinger, cadillac, couple re-re's just in case, then an all white parts car, black parts car, dyed orange car...RPM ultramolded long arm car.
- JK Racing
I think I am talking about a lot of us...and I am a Losi guy
- ChisaiKuso
- Has thanked: 5 times
- Been thanked: 27 times
Guilty...JK Racing wrote:and it begins...first just a car, then a spare chassis, then a roller to put parts on the spare chassis....then a truck & a b2, b3, team car, worlds car, edinger, cadillac, couple re-re's just in case, then an all white parts car, black parts car, dyed orange car...RPM ultramolded long arm car.
Something clever goes here...
- Blacktiger355
And more parts on the way. Got these coming from a HobbyTalk member. Steering blocks, 5,10,15 and 20 degree caster blocks as well as a nose plate, not sure about what is on it though. And it has a big triangle hole in it. But I got it all for $15.
- Blacktiger355
Black chassis/nose and the stealth gearbox came in last night. Nose has a tiny dent where the left tube mounts. Nothing major though. And the stealth is missing the slipper. Guess I will be updating to the b4 slipper.
I also seem to be missing one of the trans case spacers that go between the case and the motor plate.
- JK Racing
A&L still sells the alumunim ones (if you want bling), if not, there is an HPI spacer kit (from the Blitz) that works okay and is relatively easy to find.
- Blacktiger355
- JK Racing
- Blacktiger355
- Blacktiger355
I am also guessing I will need another motor plate for the stealth? The gold pan 6 gear one does not look to have the 4th threaded screw hole.
- Has thanked: 100 times
- Been thanked: 205 times
OldRC.com has sets of white spacers and end caps currently in stock for $12
http://sabulatech.com/storefront/product.php?id_product=2078
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- Blacktiger355
- JK Racing
on A&L, click the pictures, that is the link to the item. You can use the 6 gear motor plate, but you can only use 3 screws...kinda helps with your one missing spacer
- 2222 Views
Last post by mikenice
- 1445 Views
Last post by BLSully
- 132 Replies
- 11674 Views
Last post by RETRO R/C
- 2669 Views
Last post by Showcase1186
- 3134 Views
Last post by SoCalSnakeEyes
- 346 Views
Last post by morrisey0
- 114 Replies
- 13961 Views
Last post by YakkityYak
- 1166 Views
Last post by Jeffrysource11
