hooptys re-re
Re: hooptys re-re
I just noticed the tray you made for the esc/rx above the battery. What did you make that out of?
- Has thanked: 183 times
- Been thanked: 157 times
Re: hooptys re-re
mostly done.
im not going to put all the kit stickers on for a true boxart, but i do like the stripes.
tekin gen2 rs with a redline 10.5, hitec 7965, spektrum micro rx.
havent had it out yet but ive ran in a little inside. its got some zing.
threw on a hyperdrive with a set of 1/4" cvds. reversed the motor via hotwire.
profile
still workin' on the funco body. thinking hot pink with the boxart stickers.
i have a set of parma f&r sway bars that i intended on using, but the rear bar will require a decent amount of extra trimming on the funco.
profile
Re: hooptys re-re
Cool
I'd like to see a photo from above please
I see you used green springs on the back, but are the front ones black ?
Morten Max
Re: hooptys re-re
ill post one later. i assume you want to see the funco from the top?
green on the back, black on front. to be honest i put the soft springs on so the roller would sit with some squat. might change them for something stiffer, but they dont feel too bad.
Re: hooptys re-re
Yes exactlybadhoopty wrote:ill post one later. i assume you want to see the funco from the top?
Morten Max
Re: hooptys re-re
it fits like it was designed for the rc10. and i think it probably was...SnoopMaxx wrote:Yes exactlybadhoopty wrote:ill post one later. i assume you want to see the funco from the top?
it needs to sit a little lower and have the tops of the rear tower and shocks more snug against the inside of the body, so its going to need a little clearancing around the motor area of the body to let it sit down a little further.
- Has thanked: 36 times
- Been thanked: 1318 times
Re: hooptys re-re
is that one of those s&k impact absorber bumpers? i've had more a than a few of them but never had one out of the package and bolted to a car.
Re: hooptys re-re
yep. i didnt use the piece of black foam that comes with them. kinda goofy looking at first but its growing on me.scr8p wrote:is that one of those s&k impact absorber bumpers? i've had more a than a few of them but never had one out of the package and bolted to a car.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: hooptys re-re
The Funco body is awesome...toss that protech box-artsy fartsy thing away
- slotcarrod
- Been thanked: 45 times
Re: hooptys re-re
Liking that Funco body and your build, cant wait to see it painted!
Rod Littau
- 19 Replies
- 5767 Views
Last post by surferdave71
