RC10T2 Hoarding
- littleVETTE
- Has thanked: 6 times
- Been thanked: 9 times
- RC10th
- Has thanked: 50 times
- Been thanked: 1492 times
Re: New RC10T2 Rebuild
I've owned this truck for over 10 years and it used to be a runner but most parts on it now are new except the chassis. I wasn't planning on running it since I replaced the arms, nose plate, motor guard, shock towers, bulkheads, arm mounts, trans case, body mounts, gear cover etc. If I replaced the chassis it would look almost as good as #1.
I'm a bit over it as I probably sound like a broken record by now, but I've been trying to find a new chassis for this truck for over 6 months now.
So - so far no plans to run it, but to keep checking ebay every two days.
Hello
I don't know if it's what you're looking for but i found this while i was looking for spare for my T2
http://www.retromodelisme.com/pieces-associated-rc10t2-t1160.html
It's really expensive but it's new.
hth
Laurent
hth
Laurent
- RC10th
Wow thats a cool rare piece, 200 Euro is pretty steep.
- littleVETTE
RC10th wrote:I've owned this truck for over 10 years and it used to be a runner but most parts on it now are new except the chassis. I wasn't planning on running it since I replaced the arms, nose plate, motor guard, shock towers, bulkheads, arm mounts, trans case, body mounts, gear cover etc. If I replaced the chassis it would look almost as good as #1.
you'll eventually find one. they pop up every now and then. don't get sucked in by buying another truck. lol
- RC10th
Hmmm, look what I found. The perfect match to go in one of the T2's.
not too bad.. hope to see pictures of them running. it looks good
RC10L: ALL ORIGINAL
OFNA LX2 NITRO BB .28 ENGINE
ECX CIRCUIT: 130A ESC AND A 6000KV MOTOR
- RC10th
Although not finalized yet I should finally have a chassis on the way,
Stay tuned.....
Stay tuned.....
I think I've seen this seller's username on the forum here, but I could be mistaken...
If you're still looking for a chassis, this one looks to be in really good shape.
Trucks look awesome - best of luck finishing #2 up!
http://www.ebay.com/itm/Rc10-t2-Team-Associated-7301-Tub-Chassis-Never-Used-/171232990496?pt=Radio_Control_Parts_Accessories&hash=item27de481520
Ryan
- RC10th
I've seen his name floating around here too. I probably would have bought that chassis except I bought a complete truck which technically is better value. The sad part is then there's enough parts for a 4th T2 that could be a runner. Not sure if I'll build a 4th or use left over parts on a GT or something.
Nothing sad about that! Maybe I should pick it up and start a new project...not too familiar with the specifics on that truck though as I've been obsessed with the 10T for so long then jumped to the T3. It does seem like those parts would be easier to come by than 10T stuff?
Anyway, I say build another, but I'm not one to talk considering I've currently only got one T2 and it's still sitting in the box unbuilt
Ryan
- RC10th
I tried taking a few pictures of updates made to both trucks but wasn't happy with them, so I'll post this instead.
Both trucks are new builds. I found some correct tires for #1 so now it's 100% as it would have come out of the box. #2 received some new parts like a new chassis, Associated universals, correct spur gear, uncut battery strap and a few other stock goodies. I believe it is a very early production T2 as it has 10T type bearings (all metal sheilded except 3/8x5/8) It also has black 10T style shock collars and retainers. If anyone in the know could shed some light on this would be great.
- RC10th
Sadly I'm back to square one. Only need a chassis again
Everything here is newish and looks new, not a scratch on the nose plate or motor guard. I think I have a lead on a nice but not perfect chassis, thinking of getting it along with the nose/motor plate anodized blue.
It's not really the same truck anymore. You've replaced almost enough parts to build a third truck. I would take all the new parts off the scratched chassis and reassemble the one you've owned for 10 years. Then you'll almost be able to build a second new truck with the new parts you got for your old one.RC10th wrote:I've owned this truck for over 10 years and it used to be a runner but most parts on it now are new except the chassis. I wasn't planning on running it since I replaced the arms, nose plate, motor guard, shock towers, bulkheads, arm mounts, trans case, body mounts, gear cover etc. If I replaced the chassis it would look almost as good as #1.
- 776 Views
Last post by didou60110
- 29 Replies
- 1505 Views
Last post by Frankentruck
- 702 Views
Last post by JosephS
- 963 Views
Last post by klavy69
- 2149 Views
Last post by PTModIT
- 1024 Views
Last post by nukengineer
- 3864 Views
Last post by RC10th
- 71 Replies
- 7585 Views
Last post by R6cowboy
