Are the front towers on the 6001 and 6010, identical in height, other than the extra hole on the older version ?
In your opinion. Is the extra hole the only reason for the front ride height difference ?
So here is the "real" Re Re question...
- Has thanked: 1134 times
- Been thanked: 3934 times
Re: So here is the "real" Re Re question...
Yes, I compared them and they are identical minus the hole
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
SnoopMaxx wrote:Are the front towers on the 6001 and 6010, identical in height, other than the extra hole on the older version ?
Good questions Snoop. I was wondering the same thing. I do have a extra front tower that has both holes so I am curious what Jeff used.
I noticed you did not use the two aluminum spacers for the rear mount. Was that on purpose?
Jeff
are you talking to me? I used the stock tower which is identical to the original except they didnt drill the extra set of holes and I didnt eitherSFC K wrote:Good questions Snoop. I was wondering the same thing. I do have a extra front tower that has both holes so I am curious what Jeff used.
I didnt use the rear body mount spacers per the manual as well
the only change I made was to use shock spacers in the rear as it is cosmetically the same as the manual shows
- 673 Views
Last post by SofaKing
- 23 Replies
- 2215 Views
Last post by PBR Allstar
- 4020 Views
Last post by RC10th
- 1175 Views
Last post by RC10resto
- 635 Views
Last post by Synergy
- 44 Replies
- 7867 Views
Last post by coxbros1
- 784 Views
Last post by THUNDERSTRIKE1
- 895 Views
Last post by KV78
