Pretty much. Although most of the dirt was just dust, a lot of it, like on the shock towers and suspension arms, was this really nasty goopy crap with the consistency of tough clay mixed with rubber cement, or something like that. After this soak, I'll take the arms and hubs apart to clean them up, and fix some fit issues with the hubs. They're a bit too tight.scr8p wrote: is the stuff in that bowl going through a pre-soak soak or something? you still have a lot more parts to disassemble in there if you want to clean it properly.
Just recieved this dirty little gem in the mail
- MotoObscura
- Has thanked: 45 times
- Been thanked: 65 times
Re: Just recieved this dirty little gem in the mail
Nick DiVitto
My current vintage racing lineup: Associated RC10 B2, RC10 Team Car, Losi XXT, RC10T, XX4, XFactory X5, Schumacher CAT 2000
www.moto-obscura.com
My Youtube Channel
Hopefully it didn't bend up that nose plate to bad...And as for the hubs you can still get the roll pins for them...If you can't pull them out carefully take a dremel with cutoff wheel and get most of the pin off and the rest will pull out...Go slow and you won't hit the carrier...
- MotoObscura
All cleaned up and I just finished rebuilding it by the book. I'll take some pictures later, once I install the electronics.
For now I'm just going to use the electronics that were already in it, assuming they all still work. But I think I'm gonna race it, at least once, with a 13.5T brushless and 2s setup. I'm sure it can handle that.
Does anybody make some sort of an under body protector tray? I think I have some Carbon Fiber patterned vinyl decal sheet that I could also use to protect the bottom. I'm not too concerned, I just want to keep it nice as a runner.
Nick DiVitto
My Youtube Channel
- 2564 Views
- 39 Replies
- 4421 Views
Last post by kenooze
- 846 Views
Last post by slotcarrod
- 1747 Views
Last post by aip47-2008
- 39 Replies
- 4221 Views
Last post by carloco8
- 554 Views
Last post by esaresky75
- 351 Views
Last post by CM_113
- 1545 Views
Last post by cautiousone
