Alloy Build (FINISHED) also, undecided on name.
- GreenHell
- DMAT
- Been thanked: 4 times
Re: Alloy Build (test fit)
Looking at putting electronics in this thing too. So far the only thing I've found that I can work with is the steering servo. Turnigy MG959 v2 has an aluminum case that can be polished up. I'm not sure about a receiver, ESC, or motor yet. You guys can see what I'm going for so far so I'd be open if you have any suggestions on those items.
novak had a chrome plated receiver.
I'd look for an esc that has a big old heatsink you can remove and de-anodize and polish up externally.
a motor with aluminum endbells would probably be your best bet, or just a stock type motor with no label so its chrome.
- GreenHell
If your going brushless...
Both my Orion R10 and LRP Flow have aluminum cases and heat sinks, either one should polish up nicely.
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
That is just awesome. Hope to see you go the full monty with a chrome painted body.
Btw, I think imo the best way to solve your rear dogbone fitment is half way down the first page of this thread:
http://www.rc10talk.com/viewtopic.php?f=35&t=16610
- myfordcnc
I just want to see more sexy pictures of naked alloy. What are you doing for castor blocks and steering arms? Rims?
- DMAT
Right now, im waiting on parts for the front wheels. I'll be doing the live axle with an onboard carrier from strc that I had to drill out on the inside. I'm waiting on some hinge pins from Amain and bearings from avid. The same rod ends I have for the caster will be for the steering linkage. Im waiting on some metal spacers from mcmaster and I'll need to modify 2 rod ends to work for the center linkage.
hopefully all my orders should arrive thursday or friday so I can put more together this weekend.
just a side note, looking at strc's website, an sc10 4x4 rear hub carrier might have been a better choice for the rear wheels as it doesnt look to widen the rear.
- DMAT
order from Amain, Mcmaster carr, and avid came in. Test fit the the front end together. The front axle needed more modification to work b/c the king pin hit it. All i need now is a small spacer for the axle.
I modified 2 rod ends to be slightly shorter so they would work for the middle link.
what defines the difference between a hard pack and soft pack for batteries. I'm creating a battery cover with a 2x1x0.14" channel and after cutting it to length. Right now I have a 7.4v 20C 5400 venom battery that fits snugly inside the channel. I think the battery a soft pack but inside this case/cover/heatsink, is it now a hard pack? The battery holder part of the bulkhead will be removed for this to work. I also need to create a solution for holding down the cover.
pictures to come after I have deanodized and polished up the new parts.
hoping I have roll cage in hand tomorrow. USPS seems to have failed me again for an on time delivery.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
hard packs are in a plastic casing, soft packs are usually just shrink wrapped.
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Dont pic a color.. clear annodize it. The make an eletric turntable for it and build a lighting set up that changes color so it just cycles through numerous colors.
- 2472 Views
Last post by THUNDERSTRIKE1
- 714 Views
Last post by DennisM
- 62 Replies
- 7832 Views
Last post by Diamond Dave
- 38 Replies
- 11267 Views
Last post by limestang
- 1202 Views
Last post by GJW
- 901 Views
Last post by TycoTamiya4eva
- 3124 Views
Last post by Bormac
- 2870 Views
Last post by Caine
Users browsing this forum: Amazon [Bot] and 11 guests
