Johnboys RC10 help needed.
General info, Q&A.
Johnboy72
Re: Johnboys RC10 help needed.
Post by Johnboy72 »
Wait, I'll have to measure out the noses...maybe I can gain that back in the different noses to get my track the same. Won't be 5mm worth of arm but oh well. Just have to see what I have available.
Phin
Has thanked: 87 times
Been thanked: 249 times
Post by Phin »
Can you post pics of the arms? Are they machined nylon/delrin or molded arms?
The 55mm arms are about the shame length as a Traxxas Bullet/Rad/Sledgehammer arm. You could use them on a buggy kick-up with B4 front wheels and be at about the same width as a stock RC10.
You could probably do the same with the 65mm arms on a truck kick-up. Might be slightly wider.
Johnboy72
Post by Johnboy72 »
Ok so the late graphite is getting there. Pushing and have the car damn near cranked full left around the track. Put CW rear spacers on and think its still doing it due to the frontend is still wider. Running CW wheels. Could try putting short arms on but that will shorten my wheelbase and just mounted a Nastruck body on. Any suggestions?
Has thanked: 365 times
Been thanked: 478 times
Pics? Sounds like a front traction issue-
Johnboy72
Post by Johnboy72 »
Reg...all on my fb. I'll get them up later. Car bounces like a lowrider so dont think I got the shocks right. 30wt with#2 pistons. Also picked up a spring kit used as I was having difficulties figuring the differences between silver and golds. I did have grays on the rear.
