You got me? Not a CZZ for sure, but the diameter, depth and dish are exact to the CVR head, so I say "SCORE" because the blue looks so much cooler and less weight to boot! Both blue heads are OS and they are a different design but fit the same!justinspeed79 wrote:Looks great. What engine was the blue head for originally?
RC10GT Runner by Slotcarrod
- slotcarrod
- Been thanked: 45 times
Re: RC10GT Runner by Slotcarrod
Rod Littau
The engine you started with is a CV-X, not a CV-R.You got me? Not a CZZ for sure, but the diameter, depth and dish are exact to the CVR head, so I say "SCORE" because the blue looks so much cooler and less weight to boot! Both blue heads are OS and they are a different design but fit the same!
The blue head with 4 scallops is a CV-R head; the one you installed is a for a .12 CV Hyper, P/N: 72001110
- slotcarrod
No, the engine I rebuilt was a non pull start red head CV from an old Losi truck. I always knew the "X" in O.S. to mean pull start!
Rod Littau
- Been thanked: 5 times
You are correct about the x standing for pull start. I think what he meant was that it is a cv, not a cv-r. You referred to it as a cv-r in you earlier post. Technically it is a cv(s). The (s) denotes a short shaft engine.slotcarrod wrote:No, the engine I rebuilt was a non pull start red head CV from an old Losi truck. I always knew the "X" in O.S. to mean pull start!
That head has the same look as the hyper head, but it an actual hyper head? Doesn't the hyper have a different combustion chamber and only come in gold?
Edit: I guess technically if you cut the shaft yourself it is just plain cv. The (s) would be factory cut. Details......
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
that blue head started off life gold on the OS hyper .12. For some reason or another after the hyper was discontinued these started showing up as blue, black, or original gold per piece in the LHS around me. I'm guessing that they just had an excess and knowing they were discontinuing the cv .12s they wanted to unload these. Anyone I know that cared about weight removed those blocks of aluminum right outta the box. Some turned them sideways so they worked correctly and some just ran them til they puked and got new ones and some used them as door chocksjustinspeed79 wrote:Looks great. What engine was the blue head for originally?
Oh, I assumed you were working with the engine that came in the truck.No, the engine I rebuilt was a non pull start red head CV from an old Losi truck. I always knew the "X" in O.S. to mean pull start!
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
What ever happened to this?
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Yeah Rod.........?
RC10th wrote:What ever happened to this?
- Has thanked: 36 times
- Been thanked: 1318 times
Not sure of the timeline, but this truck may have become a casualty of his unfortunate house fire.
- TRX-1-3
Dammit. The fire. I forgot about the fire.
- slotcarrod
No it did not get burnt up but smells like smoke and is all black from soot and is rusty from the water. I tried to keep as many cars as I could from the fire but it all stinks, is sooty and rusty. I keep them all in sealed plastic bins in my detached garage. When I need a project I open a stinky bin and get to work. It's all quite overwhelming! I have been cleaning and restoring some RC10's, my TC3's and few 12 scale cars this past year. The trucks are at the bottom of the pile, but one day..... Maybe!
Rod Littau
- 23 Replies
- 4877 Views
Last post by klavy69
- 144 Replies
- 13378 Views
Last post by slotcarrod
- 25 Replies
- 4580 Views
- 2234 Views
- 2179 Views
Last post by Ranman
- 20 Replies
- 4799 Views
- 2096 Views
- 1129 Views
