But like I said before, if there is something specific you'd like Chad to make for you, just send him drawings. It's not cheap, but you'll have what you need. And that's in nylon, delrin, aluminum, carbon fiber or anything he can machine.
d
HUH??wyldbill wrote: ...you could use the standard rc-10 arms on the rear but they come up short to match the front track width. with the worlds/dynotech arms this way the suspension arms are the same dimensions and geometry as the 10t/gt just narrower.... which is one of the reasons why they got away from the wide style noseplate.
no, the 10t/gt truck front arms are 1/4" shorter than the 10t/gt truck rear arms measured from center hole to center hole. the rpm worlds arms have 3/16" difference between the two front to rear so when actually bolted to a truck chassis they would be 1/16" narrower in the front but close enough. the width of the truck front bulkhead pin hole to hole is 2 3/16" and with 0 degree rear arm mounts installed the hole to hole distance is 2 3/8" thats 3/16" difference front to rear. its a little difficult to explain without side by side pics of the 2 i am just going off of the measurements i have used over the years to build oval cars.aren't the front truck arms LONGER than the rear truck arms due to the narrow nose plate?
Users browsing this forum: Google Adsense [Bot],
Mojeek [Bot] and 5 guests
