Question: Klein rear arms, rear hub options and CVD options
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Question: Klein rear arms, rear hub options and CVD opti
Thanks for the pictures, cleared up for now..
- mdutcher
Ok, here is my newly finished project. Thanks for the info and insight.
I went with the Custom Works hub option. Here are some more pictures....
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
- mdutcher
I was able to take the car to the track this last Saturday. Out of the gate, it impressed me and all others that were there. It is so fun to race vintage stuff (somewhat modernized) and see other people's expressions.
The car handled very well. I love the big bore shocks. I need to put in some shock limiters to reduce some droop, but overall, the car handled very well.
The only other tweak is to check into the steering and button that down a little better as it seemed to under-steer.
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
FYI, I've successfully drilled an upper pin hole in the RPM 70272's so you can mount them high or low just like the losi's/cw. Just pinned them together through the existing hole, put a long 4-40 through the two turnbuckle mounts to hole them steady. Obviously, a good drill press, and a quality 1/8 reamer is necessary to get it done perfectly.
What size bearings on the custom wotks hub? I have a few sets coming to use with the b44 cvd.
Just to confirm its 3/16 x 3/8 × 4 bearing size
thanks
thanks
- mdutcher
Yes, this is the correct size of bearings for CVDs with 3/16 axles.zleader wrote:What size bearings on the custom wotks hub? I have a few sets coming to use with the b44 cvd.
thanks
- 757 Views
Last post by cautrell05
- 714 Views
Last post by RC104ever
- 749 Views
Last post by BACK_AT_IT
- 698 Views
Last post by littleVETTE
- 1019 Views
Last post by Mwp1111
- 23 Replies
- 2116 Views
Last post by RCveteran
- 1246 Views
Last post by radioactivity
- 981 Views
Last post by unclemikey1978
