My crappy Rc10-DS
ra272
Been thanked: 7 times
Re: My crappy Rc10-DS
Post by ra272 »
Thanks, yes I want to use modern hex wheels: HPI american racing wheels.
Here is the front end rebuilded with SC10 axles.
And the rear, I've just received a new rear anti roll bar, but I havent had the time to mount it yet, still haven't decided what shocks I will get. I will try polished old .56 to see if it looks good.
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
Now that is sweet! Good job, you turned that sows ear into a silk pur... mans bag ;)
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
That's not even close to the original. Amazing job!
ra272
Post by ra272 »
Thanks guys. :D
I've tested several colors, black, orange, hard coated, and my final choice is polished. I think it looks very nice with the carbon.
What do you think ?
The rear, next I will rebuildt the tranny with ball bearigs, the DS had bushing.
vintage AE
Jealous, looks very good with the polished shock bodies.
clm
Post by clm »
I think I agree with you, black and 'chrome' is a good look :)
Chris
soniccj5
Post by soniccj5 »
The re-use of the old chassis, specifically in the front is awesome. I was planning on using 10T standoffs if/when I went ot a carbon chassis, but now I will cut up a chassis that was about to hit the bin.
ra272
Post by ra272 »
Thanks, here is a quick update. Tranny is rebuildt with ball bearing, new thrust bearing balls, new aluminium dog bones.
SC10 12mm hex, HPI "american racing" rims and vintage tires (26mm front, 31mm rear).
marlo
Has thanked: 18 times
Been thanked: 22 times
Post by marlo »
WOW :shock: looking great!
justinspeed79
Post by justinspeed79 »
You took that tired old machine and turned into one of the nicest ds's that I have seen. Excellent work! 8)
Did you have to do any mods to the sc10 parts to make them work?
marlo
Post by marlo »
I'm not that good with DS's, but should that rear inner hinge pin be that long, or is it just missing a bushing.
ra272
Post by ra272 »
You need to drill the SC10 C hub as RC10DS hinge pin are bigger than B4's.
For the rear inner hinge pin, I don't know, I'll check the manual on associated website.
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
suppose to be shorter hingepin there he probably didnt have it and used that one.But a black spacer would go unnoticed in the front i bet.don
Been thanked: 3919 times
Early rc10 had the longer 6380 inner hinge pins, later they went to the shorter 7356 truck pins. The DS called for the shorter which are still easy to find.
LoboNYC
Has thanked: 870 times
Been thanked: 356 times
Post by LoboNYC »
I like the direction this built is heading towards.
