B2 Proline Tire PNs???
General info, Q&A.
Re: B2 Proline Tire PNs???
templeofspeed wrote:I'm confused. :?
pfft ............... you only figured that out now? :P :P :P
:lol:
Bugle
Post by Bugle »
Took a pic of the box if it helps
Bugle
Post by Bugle »
Also these are the original front wheels from mine, has a wider flat bit around the edge of the wheel and doesn't use flanged bearings. Other wheels on the car and all my other B2/3 rims have 6 ribs..
mrlexan
Post by mrlexan »
Is there supposed to be a pic posted above?
www.gojammedia.com
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
There's a pic up there. So the 9480 wheels are eight rib and use plain bearings. The 9481 are the B3 with six ribs. That's the kind of info I was looking for. I hope it doesn't make mrlexan's life more difficult. :wink:
Thank you Bugle!
mrlexan
Post by mrlexan »
I see nothing above.
www.gojammedia.com
templeofspeed
edit...redundant.
templeofspeed
Are we maybe shooting our own foot off here?
http://cgi.ebay.com/Associated-RC10-B2-Wheel-Tire-Set-Proline-Pro-line-Team_W0QQitemZ270186331424
The fronts look like the old TQ type judging by the bearing area... :?
mrlexan
Post by mrlexan »
I still can't see the pics.
Don't think so (shooting the foot). I don't think the fronts are correct as they are HUGE.... the are much larger than the ones I picked up at my LHS. Also the tires do not have proline molded into the sidewall. I honestly don't think they are correct.
www.gojammedia.com
templeofspeed
Ah, ok must be 2.2's. I just got some 6878 4 rib tires from AE that have smooth sidewalls. I think they're from the B3 sport.
templeofspeed
edit. redundant post.
mrlexan
Post by mrlexan »
Yes, I can see that one.... not the others (above).
www.gojammedia.com
mrlexan
Post by mrlexan »
templeofspeed wrote:Ah, ok must be 2.2's. I just got some 6878 4 rib tires from AE that have smooth sidewalls. I think they're from the B3 sport.
I should check my B3 that is partially new built. I will pull them out of the box.
www.gojammedia.com
mrlexan
Post by mrlexan »
I am about 99% certain the frt wheels I bought at my LHS are 9480Y
www.gojammedia.com
mikedealer
Post by mikedealer »
those rims use the #6906 BALL BEARINGS and for b3, b2 fronts were different i believe.
RIMS-B3 Front 2.125"-yellow(2)
2.125"; USES #6906 BALL BEARINGS
