MIP LEGENDS RUNNER RESTO.**RACING - 13 JULY ** ADDED VIDEO!!
- bearrickster
Re: MIP LEGENDS RUNNER RESTO.
what are you using for a front belt guide? thats pretty cool it looks custom yet very simple and small i like it
- Has thanked: 11 times
Its actually just a simple post with material removed to allow a bearing to sit on a small axle. The tension is adjusted by reducing or adding washers under the mount (which screws to the bottom of the chassis).
Really looking forward to running it - not sure which body to run on it.probably a viper.
Anything you guys would look better?
Cheers
Darryn
Cheers
Darryn
- Dr. Robotnik
- aeiou
Ah-ha! Super-secret parts cleaning solution revealed - algae.
j/k It's looking great.
lol - that was after JUST the rear suspension arms and bulkhead!! I had cleaned it (the ultrasonic cleaner) just 20 minutes before!
You should have seen it after the front end and other bits........
Pretty much finished now - just need to decide on a body and install the radio gear.
Cheers
Darryn
Cheers
Darryn
- Dr. Robotnik
You have an Ultrasonic cleanerRETRO R/C wrote:lol - that was after JUST the rear suspension arms and bulkhead!! I had cleaned it (the ultrasonic cleaner) just 20 minutes before!
You should have seen it after the front end and other bits........![]()
Cheers
Darryn
Decent ones can be had on eBay for less than a hundred bucks....... dont need to clear it with the wife (minister for war and finace) either - as it also cleans jewellry and other prescious metals without harming them....perfect allaby.
Cheers
Darryn
Cheers
Darryn
- Dr. Robotnik
Hahaha, my finances won't strecth for those extras but it's cool to hear about.RETRO R/C wrote:Decent ones can be had on eBay for less than a hundred bucks....... dont need to clear it with the wife (minister for war and finace) either - as it also cleans jewellry and other prescious metals without harming them....perfect allaby.
Cheers
Darryn
Actually it is pretty easy to make a basic one - just get an old fish tank pump and attach a tupperware container to it using hot glue. Turn it on and the parts get the dirt and crap shaken out of them nearly as good as the expensive ones....RPM even made one years ago - will have to get a pic of mine for you.
Cheers
Darryn
Cheers
Darryn
- Dr. Robotnik
What it just shakes? Hmmmmm...I might be able to rustle something up from parts at uni. Don't you need to spend a lot on the funny shaped packing material the parts sit in in the bowl though?RETRO R/C wrote:Actually it is pretty easy to make a basic one - just get an old fish tank pump and attach a tupperware container to it using hot glue. Turn it on and the parts get the dirt and crap shaken out of them nearly as good as the expensive ones....RPM even made one years ago - will have to get a pic of mine for you.
Cheers
Darryn
No you fill the receptacle with cleaner of choice (I use methylated spirit) - rubbing alcohol would also work. We arent polishing - we are cleaning parts and getting the grit out of bearing etc - I think you are thinking of a rouge polishing tumbler or something similar.
Cheers
Darryn
Cheers
Darryn
- Dr. Robotnik
RETRO R/C wrote:No you fill the receptacle with cleaner of choice (I use methylated spirit) - rubbing alcohol would also work. We arent polishing - we are cleaning parts and getting the grit out of bearing etc - I think you are thinking of a rouge polishing tumbler or something similar.
Cheers
Darryn
Re: MIP LEGENDS RUNNER RESTO ** COMPLETTED & RACING THIS WEEKEND
Not at all mate - my last post wasnt that clear.
Car is complete - see below!!
Cheers
Darryn
Cheers
Darryn
- 68 Replies
- 10375 Views
Last post by THEYTOOKMYTHUMB
- 3150 Views
Last post by 73rscamx
- 2667 Views
Last post by breizhator2
- 1640 Views
Last post by lexus-5
- 4030 Views
Last post by aip47-2008
- 1534 Views
Last post by Mad Racer
- 738 Views
Last post by ThomasH
- 2158 Views
