Identifying a Kyosho
- Charlie don't surf
- Has thanked: 358 times
- Been thanked: 470 times
Re: Identifying a Kyosho
Whadda ya know- its an Ultima...with a transverse battery, red shocks and funny steering
Go easy on me here guys, I am extreme novice. But I do love the classics. I spend most of my days restoring vintage Japanese motorcycles. I can definetly see the beauty here. I didn't realise my RC10 had similar steering, what I was reffering to was the dual posts and servo saver, but I understand it all now that I have disassembled it.
Doesn't look bad-surveywaters wrote:Go easy on me here guys, I am extreme novice. But I do love the classics. I spend most of my days restoring vintage Japanese motorcycles. I can definetly see the beauty here. I didn't realise my RC10 had similar steering, what I was reffering to was the dual posts and servo saver, but I understand it all now that I have disassembled it.
We weren't picking on you, we were picking on each other
I don't know, I have two. One is missing a tabe for the battery pack, another has about an inch missing toward the front which doesn't look critical. I was considering cutting a new one from aluminum. Any thoughts? I am currently more concerned about the roll cage and body. The body is really expensive on ebay and the rollcage is real pricey for a questionable used one.
Will any roll bar setups fit the Gen 1 Ultima other than gen 1 ultima roll bars? Like the Ultima DB?
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
The DB is allmost twice the size as the 1. gen. Ultima.
Perhaps is possible to make something out of a Tamiya FAV cage.
I would use either fibre glass or kydex for topdeck. It absorbs a collision better than aluminum.
Gone fishing
- Been thanked: 325 times
Whenever I see "DB", I think "douchebag".
Back to your regularly-scheduled program...
I didn't realise it served a purpase other than the obvious. Impact absorption makes since. I looked at carbon fiber, fiberglass, and kydex. The kydex looks best by far. I am seeing 0.060" and 0.080" thickness, I've never used this material and don't know how rigid it is. Obviosly I would prefer thethinner for weight but is it stiff enough?
Kydex is great for making bumpers. I made my own bumper for my CYANide on-road car from 5mm Kydex. Once you've cut it and drilled it, you can use a heat gun on it to warm it up, then make some simple bends.surveywaters wrote:I didn't realise it served a purpase other than the obvious. Impact absorption makes since. I looked at carbon fiber, fiberglass, and kydex. The kydex looks best by far. I am seeing 0.060" and 0.080" thickness, I've never used this material and don't know how rigid it is. Obviosly I would prefer thethinner for weight but is it stiff enough?
http://www.rc10talk.com/viewtopic.php?f=30&t=17726&start=58
Cool, I got some Kydex sheet as well as some carbon fiber phenolic from my sister in law who works here in town for a very large commercial plastics distributor; handy hook up
Now I still need to figure out this roll bar and body situation. I am sure I could fit a standard buggy body on it but that wouldn't be right at all.
I've toyed around with the idea of using 1/4" or 3/8" stainless steel brake or fuel line and a pipe bender to fabricate a partial roll-cage, but the part I can't do is the brazing or welding the parts together.
That's a great idea, but I don't have one to model it after, closest I have is the manual's picture. I can do a little brazing with aluminum. Harbor Freight sales low temp brazing rods that work with MAP gas and a propane torch. They're really easy to use.
http://www.ebay.com/itm/NEW-K-S-Round-Aluminum-Tube-1-8x36-5-1109-NIB-/390562879812?pt=Model_Kit_US&hash=item5aef5c9944
- 1675 Views
Last post by oldjoes
- 23 Replies
- 3698 Views
Last post by RichieRich
- 988 Views
- 1319 Views
Last post by sgirouard
- 752 Views
Last post by Falsepleasure
- 1007 Views
Last post by nvxwax
- 812 Views
Last post by DerbyDan
- 1082 Views
Last post by fieldbaja
