Installed a 8.5 BL and +8mm Chassis
Orange
Re: Installed a 8.5 BL
Post by Orange »
If it jacks you up, then instead of changing back to the softer spring, make your rear camber link longer and try that first before you change it back...
I might be more inclined myself to put a washer under the inside camber link ball at the same time I switch to stiffer spring. But knowing the feeling of each change is important I think.
Sean Sanchez
Gallery:
My feedback
soniccj5
Re: Installed a 8.5 BL and +8mm Chassis
Post by soniccj5 »
Thanks for all the tips.
Just finished my +8mm upgrade.
fredswain
Post by fredswain »
Wow you think you need more than a 10.5 on that track? I'd have never guessed more than a 13.5 would be all you'd need. Our clay track is at least 4 times larger than that and people run 8.5 on it. I'm fine with 10.5 on it.
soniccj5
Post by soniccj5 »
fredswain wrote:Wow you think you need more than a 10.5 on that track? I'd have never guessed more than a 13.5 would be all you'd need. Our clay track is at least 4 times larger than that and people run 8.5 on it. I'm fine with 10.5 on it.
Might be overkill, but it helps me clear some of the larger jumps. Maybe once I learn how to drive better I won't need it :-D.
fredswain
Post by fredswain »
I can land on my roof at any speed! :lol:
soniccj5
Post by soniccj5 »
fredswain wrote:I can land on my roof at any speed! :lol:
I am very good at doing cartwheels myself :lol: . I always think after it is done I will see a wheel flopping around, but it keeps on going.
