terry.sc wrote:Which do you think is more likely to cause wear on the inside of the gearbox and chain guards. A metal chain that has been tensioned to keep it on the pulleys, or rubber belt teeth that aren't under tension. If it did wear as much as you suggest we would have found plenty of Optimas with the gearbox case and chain guides worn through by the chains.
You misunderstood my idea of "wear"; I was referring to the
belt wearing on the inside as a result of it rubbing the gearbox and chainguide floor; not the gearbox/chainguide wearing. I guess the belt is more durable than I thought, as it's allowed to rub the upper exit channel and chainguide floor without the idler pulley installed and from what you guys are saying, it causes no harm. Oh well, I guess Kyosho Option House was out to lunch when they included the idler pulley in their conversion kit.
Oh well, thanks for the info; if I do another Optima belt conversion someday, I'll try it without any modding and see for myself. Sure would save me a lot of time, as I put in a lot of work to fabricate my own belt conversion just like the Option House conversion kit instructions.
