help with vintage rc10 racing
Has thanked: 220 times
Been thanked: 320 times
Re: help with vintage rc10 racing
You can use big bore shocks as Scr8p mentioned, don't be surprised if most guys there don't exactly know what it is :roll: I ran one bi-weekly for a year against guys with current stuff, A Mained ahead of them and they still didn't know what it was-
JK Racing
Has thanked: 129 times
Been thanked: 242 times
Post by JK Racing »
kyoshoracer77 wrote:so why cant i run the big bore shocks?????
My pictures above (and below) have the Losi BB shocks on the car. Those towers are fine, they are what I run.
kyoshoracer77
Post by kyoshoracer77 »
scr8p wrote:who said you can't use big bore shocks?
if you did not get longer rear arms, those b44 cva's are of no use to you.
i got the rpm front an rear arms.
kyoshoracer77
Charlie don't surf wrote:You can use big bore shocks as Scr8p mentioned, don't be surprised if most guys there don't exactly know what it is :roll: I ran one bi-weekly for a year against guys with current stuff, A Mained ahead of them and they still didn't know what it was-
i thought most of u guys would know about the new 12mm big bores from associated????? they r smoother than the standard associated shocks
I have Kyosho 12mm on my B44.1, TLR 12mm on my 22SCT, and AE 12mm on my SC10. The first two are better
kaiser
Post by kaiser »
i think he meant don't be suprised if they don't know what an rc10 is. lol
askbob
Post by askbob »
JK, any noticable differences in how the car handles and jumps with those shocks versus the old stuff?
Has thanked: 33 times
Been thanked: 1178 times
if you didn't get rpm "worlds" rear arms, go back to my original statement.
JK Racing
Post by JK Racing »
askbob wrote:JK, any noticeable differences in how the car handles and jumps with those shocks versus the old stuff?
Very smooth on the track. I put them back onto my 22 for now, the stock gold shocks are back on there, the car is very edgy now. Cant wait to get a set of BBs dedicated for this car.
kyoshoracer77, using the "standard" rear RPM arms (only ones still available, unless you find the "worlds" style off eBay), the B44 cva's can only be used with a modified B4 rear carrier (drilled for the larger hinge pin hole). You can use B4 wheels after that, but you will be narrower. I personally am a fan of B2/B3 cvd's with correct bearings in the rear hubs and the TT rear wheels. Keeps the geometry exactly the same as designed.
FYI, to tell the difference between standard and worlds style arms, standard have 3 shock mount holes, worlds only have 2.
mdutcher
Post by mdutcher »
What shock springs were you running front and rear on your BBs? What weight of oil would you recommend to start with front and rear? Thanks for the great info!
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
JK Racing
Post by JK Racing »
Stock 22 springs, red front, yellow rear...55 pistons, 30 wgt all the way around. Was quite hot so indoor/colder weather, I would drop the oil.
Sorry for the hijack kyoshoracer77. Back to our normally scheduled thread :)
kyoshoracer77
JK Racing wrote:Stock 22 springs, red front, yellow rear...55 pistons, 30 wgt all the way around. Was quite hot so indoor/colder weather, I would drop the oil.
no need to be sorry jk racing, answering the questions is how we all learn about what works. i do have b4 rear hubs, but how narrow is compared with the stock rc10??
kyoshoracer77
I WISHED ASSOCIATED WOULD REMAKE THE RC10 GOLD CHASSIS,
WILL RC10GT REAR ARM MOUNT WORK ON OUR BUGGYS???
OR DOES CUSTOM WORKS MAKE ANYTHING??
JK Racing
Post by JK Racing »
no, GT arm mounts will not work. best/only bet, eVilBay :(
1/4" or more, I dont exactly remember. You can use the Custom Works axle spacers to get some back. I think scr8p has pics floating around of what they look like mounts. You will be forced to use low profile nuts with the spacers.
In the Tech Section, we have a good thread about set ups, shocks, springs and such, makes for good reading and great place to post "my car is acting like this, suggestions" type questions :) it helped me a lot in tuning the car at the track.
kyoshoracer77
JK Racing wrote:no, GT arm mounts will not work. best/only bet, eVilBay :(
yes that section does help alot!!!!! thank u. i will have pics posted as i do the build. this is my first rc10 build. i see u guys like the (TT) wheels, the only reason i want to do the b4 wheels is cause i got a lot of them to use. i wish i could find all the rear mounts for the rc10.
i was on ebay looking at rear hubs and saw soom tc6-tc5 rear hubs and wonder if they would work???.
Users browsing this forum: No User AvatarGoogle [Bot] and 0 guests
