Old slipper, new transmission options
General info, Q&A.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Old slipper, new transmission options
Post by klavy69 »
The spacer looks good. Let us know how it works out for ya...
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Maybe I am thinking wrong, but couldnt you use the inner hub from the SC10 slipper and the outer hub from the OG stealth? Losi's slipper plates have stayed the same through all their models, from single slipper pad, hydra & dual slipper pad. Same basic set up should be easily do-able with stealth.
cautrell05
Post by cautrell05 »
The inner sc10 hub is just a little smaller than the stealth and loses a little surface area. It would probably work depending on how much the slipper gets used.
JK Racing
Post by JK Racing »
if you run the slipper pretty much locked, shouldnt be an issue. Maybe use a Losi inner hub (ever so slightly larger)?
