vintage stock RC10
- markbt73
Re: vintage stock RC10
Radio adapter plugs can be a little hard to come by these days, especially since almost everything is more or less universal now. I assume the Futaba plug you're talking about is the kind with 3 prongs sticking out of the plug at 90 degrees? You'll have a devil of a time finding an adapter for those. Futaba stopped using them in about 1986.
You might be better off upgrading to an inexpensive newer 2.4ghz radio. There is a Chinese-made one available for very cheap, like $25 (sold under the Flysky label) or you can get better-known brands for about $60-70. Any of them will have better range and less interference than your old Magnum, don't ever require a crystal, and they'll have the universal-style servo and ESC ports on the receiver. Something to think about.
Yes. 3 prongs at 90, Futaba G I think it's called.
Soldering it in place of the receiver plug on the vl5 esc I thought would be a simple fix.
Think the Futaba receiver is gonna have trouble with this esc?
I have an extra servo with the Futaba G for a donor.
Pull out my old speed control, put in the xl5, buy a new battery, and I'm down the road....maybe.
Wanted to make a short adapter so I didn't have to cut the esc...but it probably doesn't matter.
- Russ Winn
- Has thanked: 49 times
- Been thanked: 80 times
I was just reading this thread, and see you were looking for charger options. I recently purchased this one, and have been pretty happy. It does Nicd, Nimh, Lipo, Life, and lead acid.
http://www.all-battery.com/tenergytb6b-charger-combo-90263.aspx
UPDATE:
Thanks for all the help guys!
Ended up spending abt $120 to get it on the road...but over half was on getting a charger which could be used for lipos in the future. (Onyx 235)
-went with Duratrax Mod ESC
-changed to 17T Reedy Radon
-and a NiMh battery for now.
It is definitely a bit faster than before. One problem with faster is that it makes it more obvious when it is not going straight.
Anyone have a trick for adjusting the steering? Using original RC10 setup. Seems that turning Left works fine, but upon release from Right turn the servo doesn't seem to bring the tires back to center all the way.
Servo seems to travel same distance both ways... I can't tell where the slop is.
- Russ Winn
Try disconnecting the servo linkage from the bell crank, and check for any binding or contact. If you're using a straight servo arm, it could be flexing, or if you use a Kimbrough type saver, the spring could be worn. If everything is good, you could possibly have a servo problem. I had one with a weak motor once, and have broken gears several times before (easy fix). Most likely, it's only a bind in the linkage somewhere.
- RC104ever
If you want better steering, start here and get the bell cranks kit with ball bearings:
http://vintageteamaandl.com/
Next, if you want to go FAST (assuming you have a stealth tranny), go here and order a set of JC Racing 5 spoke wheels:
http://www.jcracingproducts.co.uk/products/
Proline Caliber tires (good all purpose tire with reasonable wear)
http://www.amainhobbies.com/product_info.php/cPath/1_26_2338_2339_213/products_id/169000/n/Pro-Line-Caliber-M3-22-Rear-Buggy-Tires-2
Get a Gens Ace Lipo:
http://www.hobbypartz.com/98p-65c-5000-2s2p-hardcase.html
Get this 2.4 Ghz radio and receiver:
http://www.hobbypartz.com/79p-gt3b-carradio-lcd.html
Get the Sidewinder3 ESC + 4600 kv motor: (if you want to go silly fast, get a Mamba Max with the 5700kv motor)
http://castlecreations.com/products/sidewinder3.html
If you get all of the above, you will be ready to fly against the RTR stuff! If you need parts, here is one good place to try:
http://sabulatech.com/storefront/category.php?id_category=18
I also strongly recommend upgrading your shock towers once you start going faster as they WILL break easier:
http://rccarbonworks.com/store/index.php
I would also suggest these arms as upgrades to the stock ones:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAF4&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEU95&P=7
Good luck! I made an RC10 for my son and did a bunch of these upgrades for him and he loves it. We raced a RTR car and absolutely CRUSHED it with the gold pan. When we told the kid it was over 20 years old that just made the kid even more upset, lol.
Now everyone wants to race us
- Chris
Lots of cars...so many cars
Thanks for all the advice.
Spent some time with the steering and it is better until I can upgrade.
Tried a youtube trick I saw and stuck my Garmin inside the car, set for new trip and ran it down the street.
It registered 22mph as max speed for trip. I know this isn't stellar, but definitely much faster than I remember it running as a kid. Garmin probably adds a little weight to the car too.
What would be the top speed of a bone-stock RC10?. Mechanical speed control, stock motor, 6 gear...etc.
Anyone tried to strap a Garmin on one?
- 957 Views
Last post by ls1heli
- 845 Views
Last post by Frankentruck
- 899 Views
Last post by Johnboy72
- 19 Replies
- 2876 Views
Last post by glock_9mm
- 2581 Views
Last post by CTYankee
- 1742 Views
Last post by PBR Allstar
- 1431 Views
Last post by rc-stu
- 1321 Views
Users browsing this forum: Bing [Bot] and 3 guests
