FINALLY found some help with the 5 pins for the module connection, Pin 1 - PPM, Pin 2 - positive power, Pin 4 - negative ground. Was it really that easy? yep...took an hour to put the radio back together.
Pics when I get home tonight and clean up the install, I rushed it last night so I could test, tested perfect. Put the receiver into the Goldie and did a little run up/down the street, went almost as far as I could see with no issues
