SWB Optima Mid Undertray
- Jirka
- Has thanked: 33 times
- Been thanked: 24 times
Re: SWB Optima Mid Undertray
Sarik named company made SWB MID undertrays. It was not "full lenght" undertray so chassis areas below diffs were not covered.
One possibility is just to make one from flat lexan and then cut, bend, cut more, bend more and use some tape to keep bended areas lifted.
Jirka
Jirka
That would probably be OK from a functional perspective but I'm aiming for something a little more elegant for my shelfer
Trying to shorten a LWB undertray would probably work out better than trying to bend a flat sheet
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
You know, undertrays really were designed to keep debris out during track time. Would you really need one on a car that which was not standard which will only sit atop a shelf?
Not kicking tyres here, but maybe you really want to get this Mid of yours back out on to the track at some point?
Good point, that is why I would buy more than one undertray
There is also a bit of a theme to this particular shelfer
- losiXXXman
- Been thanked: 5 times
Aside form HCP remaking his trays, cutting up a LWB one to fit would not be that difficult I think. It would basically be like doing a chop or section on a hot rod. Make a straight cut perpendicular to the car's centerline, and then nest the back piece into the front. Slide it forward until it suits the chassis length...
- j0pp3
- Been thanked: 4 times
That might work if the SWB body has the same angles as the LWB undertray. I have a few samples of each at home so I might try it out after work (if I still remember this topic)losiXXXman wrote:Aside form HCP remaking his trays, cutting up a LWB one to fit would not be that difficult I think. It would basically be like doing a chop or section on a hot rod. Make a straight cut perpendicular to the car's centerline, and then nest the back piece into the front. Slide it forward until it suits the chassis length...
Cheers
Joel
Joel
It would be great if you could do that because I was thinking just the same thing but don't have access to a SWB shell to compare against
- j0pp3
Okay, mission accomplished! Pushed the LWB under tray forward in the SWB body shell and the angles are slightly different but may work with some Velcro perhaps?
Cheers
Joel
Joel
- Been thanked: 325 times
Something...like this?J.M. wrote:I wish someone would knock up a mold for the original Optima line of cars too. I tried the cut and shut years ago myself with parts of lexan. Yes, it did end in tragedy![]()
http://www.rc10talk.com/viewtopic.php?f=30&t=21530&start=104
While it's not a full under-tray, it at least protects the underside. The design is simple yet effective, but the one thing I'm re-working is the number of holes needed to insert screws into. The design I came up with for Barney has no less than 12 holes in it....aligning all those holes perfectly can be a royal PITA. I'm thinking of something simpler for CYANide.
P.S. This is my design but I had help from ROH73 to make this. Thanks!
Joop: if you pull the undertray away from the body a little so there is less overlap is the angle mismatch reduced?
Coalacanth: That was a pretty cool idea for the Optima
Have you had a chance to see if you still have the mold?Hcp22 wrote:I did a mold 23-24 years ago; I think I sold around 150 under trays back then in Sweden. But I never saw any one other making them. Maybe I should look up the old mold and make some more if I still have it…
- Hcp22
- Been thanked: 22 times
- 23 Replies
- 3099 Views
Last post by Lonestar
- 31 Replies
- 3411 Views
Last post by alcyon
- 3699 Views
Last post by alcyon
- 1968 Views
- 2305 Views
Last post by Jerzi
- 59 Replies
- 8026 Views
Last post by j0pp3
- 3191 Views
Last post by Bo Wallen
- 19 Replies
- 9157 Views
Last post by lin6499
