Nope, thats a chopped and glued chassis, I'm sure of that. And as far as the slipper goes, many of us are running the slipper setup from a sc10 4x4 and I believe avid also just came out with one that is much more intuitive.Jay Dub wrote:That looks to me thta it might be a new molded chassis. As far as the slipper cover, I can understand it. I have recently found that my V2 slipper can become very inconsistnt because of heat. The biggest problem is the glazing of the slipper plates (yes the aluminum pieces), and consiquently the pads . I have found that i have to replace them more often than I like in order to keep them consistent through an entire run. I have converted to the "High Torque" pads and vented plates, and this helps. But they still need to checked regularly. -Jeff
B4.5
Forum rules
Re: B4.5
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
Re: B4.5
wow Reg, it feels like I've been out of the loop for ages. Great job on the buggy...you should paint more often too
Cool to see some modern chassis mods.
Go kick some arse with that thing!
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: B4.5
that gear cover looks awfully similar to a Proline B4 gear cover set up I spied at the HRH Shootout (along with gear and slipper parts), I just couldnt get that close.
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 470 times
Re: B4.5
Start of the process-
Had to make a new cutting tool for the job Cut the bulkheads, then worked on the edges- More after I race it tomorrow night-
marking at 10 & 20mmHad to make a new cutting tool for the job Cut the bulkheads, then worked on the edges- More after I race it tomorrow night-
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: B4.5
wow that's some serious cosmetic surgery here!! nice
Jeff - why do you think we have so much wear in the slippers now? BL torque?
paul
paul
- JHarris
Re: B4.5
It's a combination of things. The motors are much better, but so are the batteries and tires. Add to that the track surface and it's like running on concrete with a ton of power and very little wheel spin. There has to be give somewhere. In the old days the tires would just throw dirt from the fluffy track surface and all was good. Now it's wheelies on demand.
On a side note; the gear cover venting is not new. That's been a fairly common mod for a year or more.
- Lonestar
Re: B4.5
Thanks for the explanations. With great power come great responsibilites and vented slipper covers
My skills only allow me to run mild mods (think 8.5's and such) hence I've never felt the need to vent my V2 cover but I'll keep an eye on temps from now on
Useful! thank you
Paul
Thanks for making me feel out of touch (which I actually am, to be honest)JHarris wrote: On a side note; the gear cover venting is not new. That's been a fairly common mod for a year or more.
Paul
- Has thanked: 25 times
- Been thanked: 29 times
Re: B4.5
Nice work on the B4, if you want to take a look at a slim b4 check the car me and my buddy made:
http://www.oople.com/forums/showthread.php?t=45259
If in doubt go flat out!
- askbob
- Been thanked: 4 times
Re: B4.5
Headling wrote:Nice work on the B4, if you want to take a look at a slim b4 check the car me and my buddy made:
That is cool! Isn't this basically leaning towards what the 22 is already?
- vintage AE
Re: B4.5
That's some crazy crap there, I love it!Headling wrote:Nice work on the B4, if you want to take a look at a slim b4 check the car me and my buddy made:
Re: B4.5
Cheers guys! This was built way before the 22
On the shelf now as mid motor is the thing in the Uk as we race on high grip AstroTurf and carpet etc
Had technical drawings done but as it has machined kick up was going to be too expensive to make, was good fun project though
