Showcase's Kinwald Worlds inspired WOIN build
Showcase1186
Re: Showcase's Kinwald Worlds inspired WOIN build
Post by Showcase1186 »
Can I dye the Klein arms?
askbob
Post by askbob »
Yes you can.
Showcase1186
Just ordered a set of Klein arms front and back. Updated the master BOM.
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
the klein arms take dye really well
Showcase1186
What do you use to dye the parts and how do you go about it?
vintage AE
I used clothing dye that you can get just about everywhere. Follow the instructions one the box...bring water to a boil, turn down heat to low, add dye and mix. People leave the parts in for different lengths of time depending on colour used and how dark they want the colour. I used black and left the parts in for about 30mins. I either place a wooden spoon or something to put on top of the pot and use dental floss to hang parts so nothing touches the pot or stir the parts so they don't rest on the bottom of the pot.
Showcase1186
TIME FOR AN UPDATE.
Here's the worlds body and the decals I got re-created by a local graphic artist. They are not exact, but very close:
Here are some pics of my parts pile:
Take a good look at the white parts in the pyrex dish waiting for the hydrogen peroxide treatment. Note how yellow they look:
There are 3 spectrum's of UV light that can be emitted; UV-A, UV-B and UV-C. DANGER, UV-C is used for germicidal eradication. It basically scrambles the DNA so cell division / reproduction is unable to occur, NASTY STUFF.
UV-A and UV-B are what you will be looking for if you want to purchase a light to whiten your parts. Typically a reptile heat lamp or plant growing lamp will do the trick. I purchased a ZILLA brand UV light from Amazon.com, $36.00. You really want to search for a light that emits a high UV-B spectrum. Mine emits 93% UV-A and 7% UV-B. The UV-B is helpful in whitening the parts in conjunction with hydrogen peroxide. It's been sunny outside, but I wanted to see how well the UV light would do on its own. Let's face it, we typically work on our RC Hobby when the weather isn't so pleasant. Please note all parts were cleaned with a toothbrush, holes were cleaned with fuzzy stick art/craft pipe cleaner and dish detergent prior to being whitened. Here is the pic of my UV / peroxide set up:
Here is a pic in relation to an untreated part after 24hrs:
mm.yokomo
Post by mm.yokomo »
Very interesting project. Any updates?
Showcase1186
I have been progressing on another project, but plan to continue the build late fall / early winter. It will be well documented and completed throughout the winter months. In fact I just ordered the ESC yesterday, it's an associated clearance ESC, LRP IPC V8.1 no motor limit. I also got a reedy 11turn double modified on clearance from associated.
REMJ666
Post by REMJ666 »
Nice build..I jotted down some part numbers also :) Thanks for taking the time to list all the stuff you used..
Showcase1186
Not a problem. Glad my research helped others. The project is still alive, but on the back burner.
fakiee
Post by fakiee »
What strength peroxide did you use for whitening?
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
Where did you find the Oakley decal?
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Showcase1186 wrote: the decals I got re-created by a local graphic artist. They are not exact, but very close
I think its a vinyl re-pro Rod, check that quote.
Showcase1186
fakiee wrote:What strength peroxide did you use for whitening?
Just the typical cheap stuff at the drug store.
Users browsing this forum: No User AvatarGoogle Adsense [Bot] and 5 guests
