Can this buggy be raced without spending a fortune?
- PBR Allstar
Re: Can this buggy be raced without spending a fortune?
about the least you can get away with for a decent combo is the speed passion stock spec system, it really is the bottom rung though, if other people are out there with better motors (stock esc is pretty much all the same in brushless, as long as it's a "non boost" class) you will get out motored.
http://www.amainhobbies.com/product_info.php/cPath/1_221_911_1949/products_id/195688/n/Speed-Passion-Cirtix-Series-Stock-Club-Race-ESC-and-Motor-Combo-175T
basically, if you're going stock class racing and you want good battery, and brushless setup expect to be spending in the $250 range.
Really though, just put a battery in and take the car to the track, it's fun bringing out a 20 year old racer, lots of attention, you'll get some conversations going, and who know's somone may help you out with some better electronics, happens at the track all the time. Work on it one piece at a time and just HAVE FUN!
- PBR Allstar
- PBR Allstar
Here's the battery I mentioned above.
http://www.hobbyking.com/hobbyking/store/__24222__Turnigy_nano_tech_6600mah_2S2P_65_130C_Hardcase_Lipo_Pack_USA_Warehouse_.html
Turnigy also makes a good lipo charger, the accucell-6. I have a couple of them for my track chargers.
Another thing about brushless racing. Most racing, espcially if it's labled as "stock" class will be very specific on rules, it will usually be a 17.5 sensored brushless motor (some places run stock class with 13.5 motors). Basically all I'm saying is check out the rules for the class you want to race, usually if it's a brushless stock class and you show up with older brushed equipment no one is going to raise a stink. So just make sure you get the most versitile equipment for what you want to do.
Well I'm not spending $250.00 for sure, I'm not really looking to go out and blow doors off, but I want to be able to keep up and not get blown away either. I'm just trying to figure out how I can best make that happen and not spend a fortune doing so. I know it will be fun, one way or the other though and thanks so much for the advice.PBR Allstar wrote:about the least you can get away with for a decent combo is the speed passion stock spec system, it really is the bottom rung though, if other people are out there with better motors (stock esc is pretty much all the same in brushless, as long as it's a "non boost" class) you will get out motored.
RC10talk.com is like a bad accident, I just can't stop looking at it...
- PBR Allstar
then I say just pick up a battery that will get you around the track and get out there. see what class you'll fit in best and ask around about equipment. Nothing wrong with buying used equipment either if it's well cared for.
That said, here is a battery charger/power supply that will get you going and is good piece for the money.
http://www.ebay.com/itm/Imax-B6-Lipo-Nimh-Nicd-Battery-Blance-Charger-LED-Charging-Adaptor-CWB6TB-/270959550422?pt=Radio_Control_Parts_Accessories&hash=item3f16729fd6
And a battery that is budget minded that will get you around the track just fine.
http://www.ebay.com/itm/5000mAh-7-4V-7-4-30C-RC-Car-Lipo-Battery-Akku-Hard-Case-/120872359834?pt=Radio_Control_Parts_Accessories&hash=item1c248dd79a
Well that sounds like good advice to me, battery and charger first and then I can fine tune the buggy chassis as i go along with other mods.
I recently puchased some Gens Ace hard case LiPo's (ROAR approved), and so far they are great. I think they were $29 a pack, and free shipping if your order is over $50 (so you should think about purchasing 2). I did allot of research, and they were the cheapest ROAR approved LiPo's I could find. -Jeff
Jay Dub wrote:I recently puchased some Gens Ace hard case LiPo's (ROAR approved), and so far they are great. I think they were $29 a pack, and free shipping if your order is over $50 (so you should think about purchasing 2). I did allot of research, and they were the cheapest ROAR approved LiPo's I could find. -Jeff
Best deal out there. I run 5000mah 40c Gens Ace in my B4.1 and SC10 4x4. 10.5 and 5.5 turn. Nobody out runs me on the straightaways, everywhere else is a different story
Well that sounds like a good deal, I'll check into them for sure and thanks for the info.Jay Dub wrote:I recently puchased some Gens Ace hard case LiPo's (ROAR approved), and so far they are great. I think they were $29 a pack, and free shipping if your order is over $50 (so you should think about purchasing 2). I did allot of research, and they were the cheapest ROAR approved LiPo's I could find. -Jeff
I believe they are from HobbyPartz.com. You can get them on e-bay, but they are way overpriced. -Jeff
HobbyPartz website says it's out of stock on those units, but I will keep checking back as it will be a few months before I try to take this to the track. Thanks again for everyone's help, you guys are the best...Jay Dub wrote:I believe they are from HobbyPartz.com. You can get them on e-bay, but they are way overpriced. -Jeff
Good inexpensive sensorless esc. U.S. Supplier. Hobbywing is top notch. I have 3 of them.
http://www.largescaleremotecontrol.com/Hobbywing_EZRUN_60A_SL_Brushless_ESC_for_1_12_and_p/c-ezrun-60a-v2.htm
Then hunt yourself down the motor you want.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
a proper servo will make more difference than anything else one can think of....
paul
paul
Oh, forgot. I have made some purchases from RC Echo as well. They have a number of combos available. Hobbywing 60a escs with a motor less than $100.
They also sell the Leopard combo for about $60. We had a guy at our track that used the Leopard forever.
As with any of the electrics just be sure and research what you can and cannot do. 3 cells can destroy an esc with the wrong combination of motor/esc/gearing.
Ron
Ditto on the servo comment. Tires/Servo/ and a way to get the power to the ground is what is needed. The good thing is, for light cars like this the high c ratings are not really needed in a battery meaning you can get them dirt cheap.
Ron
What do you guys consider a good servo?Lonestar wrote:a proper servo will make more difference than anything else one can think of....
paul
- 665 Views
Last post by Frankentruck
- 65 Replies
- 4477 Views
Last post by MelvinsArmy
- 1542 Views
Last post by mrgrimm
- 1490 Views
Last post by vwjuice
- 499 Views
Last post by soniccj5
- 1643 Views
- 1448 Views
Last post by BillKrueger
- 1629 Views
Last post by Group B
