SEETHING: Building garbage Associated shocks
- flipwils11
- Been thanked: 19 times
Re: SEETHING: Building garbage Associated shocks
I can't put the quote under my avatar that I have on other sites where profanity is allowed, but if you've seen "Heat" and remember the scene where Al Pacino is shaking down the snitch at the Porsche chop shop, you'll understand that I don't like to have my time wasted. Lol. An entire evening of quality RC time last night was shot because of those damned Ass-ociated shocks!
Or, for you Lebowski fans, the shocks were messing with my zen thing, man.
- Been thanked: 4 times
Know how it is ,i rebuilt 12 shocks yesterday.Sanding the plastic sure helps,it clicks right in after that.I just cant seem to do bottom fed shocks,i smash them lol DON
I had a similar issue with my top loaders, as well as my V2 shocks. The original red o-rings wouldn't fit properly. I tried NIP ones as well as slightly used ones, and they were no better. I looked at them compared to several other brands of o-rings and they looked larger. I eventually put the Kyosho X-rings in (clear) and they were perfect. They are a little more pricey, but they last much longer than AE units. I found the AE red units swell alot, and can make rebuilding near impossible. BTW, I have never had to sand down any spacers. -Jeff
- Has thanked: 67 times
- Been thanked: 45 times
I allways file down the spacer in a "snap-shock", it makes it a bit more smooth.
Also I use different O-rings, there called "801's". I had them made with a softer rubber and slightly diffent size than the stock versions.
Here in the Netherlands and Belgium most top drivers use them, also quite a few in the UK.
In the V2's I also like to sand the spacer since I hate leaving the bottom unscrewed slightly.
Genius by ignorance
- Has thanked: 7 times
- Been thanked: 42 times
Janus, do you have a link for where to get these 801's? Thanks!Janus wrote:I allways file down the spacer in a "snap-shock", it makes it a bit more smooth.
There not availible over the internet. Usually there sold at bigger races. But I can send you some if you want to try. Just send me a PM with details.adam lancia wrote:Janus, do you have a link for where to get these 801's? Thanks!
Genius by ignorance
- askbob
Jay Dub wrote:I had a similar issue with my top loaders, as well as my V2 shocks. The original red o-rings wouldn't fit properly. I tried NIP ones as well as slightly used ones, and they were no better. I looked at them compared to several other brands of o-rings and they looked larger. I eventually put the Kyosho X-rings in (clear) and they were perfect. They are a little more pricey, but they last much longer than AE units. I found the AE red units swell alot, and can make rebuilding near impossible. BTW, I have never had to sand down any spacers. -Jeff
You mean these?: http://www.ebay.com/itm/360377462140?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Yup, that is them. I like them allot. They also make an orange set as well. I don't know if they are the same material though. -Jeff
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 470 times
I thought I went to heaven when I disovered the clear x rings
I'm going to have to order a few sets of those. I mentioned to the guy behind the counter at hobbytown about this same problem last year, no help. Just said to contact AE's customer service. I swear if it's not Traxxas, they just don't care!
- 2068 Views
Last post by LowClassCC
- 31 Replies
- 2891 Views
Last post by Tadracket
- 2386 Views
Last post by RedScampi
- 3387 Views
Last post by hondaman
- 797 Views
Last post by vintage88
- 1529 Views
Last post by mamadoesntletme
- 2079 Views
Last post by JosephS
- 688 Views
Last post by RC10th
