Street setup for rc10 build
njdriver04
Re: Street setup for rc10 build
Post by njdriver04 »
scr8p wrote:a ds tower isn't going to bolt up to those arm mounts.
how different anyone have a side to side photo of th ds and the stockers?
the DS uses a different nose plate altogether, along with nose tubes, shock tower, arms and arm mounts. in the rear, you have the rear arms and dogbones/universals and shock tower. They shorten the wheelbase slightly and narrow the car to 200mm wide.
Check rc10.com under the manual section, under 'discontinued models' and compare the RC10 to the RC10DS manuals for pictures of the complete assembly.
rc10johnny
Post by rc10johnny »
Or you could look in the DS section threads :shock: :mrgreen:
njdriver04
Thanks for the input guys,
rc10johnny wrote:Or you could look in the DS section threads :shock: :mrgreen:
I'm new to RC10talk didn't know there was a section, after a little fabrication I am only using the DS front tower, so hopefully this thread will stay relevent to this section
Saw that, I really like what that guy did.
jwscab wrote:the DS uses a different nose plate altogether, along with nose tubes, shock tower, arms and arm mounts. in the rear, you have the rear arms and dogbones/universals and shock tower. They shorten the wheelbase slightly and narrow the car to 200mm wide.
check'd out RC10.com, couldn't figure out what the DS arm mounts look like, for now I am going to use th DS tower with some fabrication, I want to keep the wider stance of the regular rc10s with some toe in, for the rear I am planning for now to just use the stock tower a set of front shocks, maybe drill a different hole to mount the shocks at a different angle.
njdriver04
one question should i put in the heaviest viscosity fluid in the shocks when I rebuild them, same front and back?
Has thanked: 3709 times
Been thanked: 1980 times
njdriver04 wrote:one question should i put in the heaviest viscosity fluid in the shocks when I rebuild them, same front and back?
In my opinion the viscosity won't make too much difference unless you're setting it up for one particular track or set up. I'd just go with a 35-40 all the way around. That's not to say that viscosity doesn't make a difference, but that's getting into some pretty fine tuning. I think what Johnny meant was just to look for some DS threads within the forums that already exist. You can probably just attach some fabricated stems to the bulkhead for rear shocks. Keep in mind that the shock towers don't necessarily have to be attached to each other in the rear. You could use two seperate pieces of fiberglass or something.
njdriver04
i think i have enough 35 from my sledgehammer rebuild. I am going to go poke around the DS section after I replace the leaf spring bracket that broke on my 96 Ranger
njdriver04
here is a comparison to the DS and regular front shock tower
Users browsing this forum: No User AvatarBIGDADDYBUILDER and 8 guests
