834B Wing Buttons
- duckhead
- Has thanked: 162 times
- Been thanked: 205 times
Re: 834B Wing Buttons
Resurrecting this old thread as I am doing some current research in this area. Al, these ZB-50 wing buttons you have are curious as they have a through hole drilled in them for the wing wire capture screw.
The 843B I recently picked up only has a small "pin" hole at the bottom:
Others I found scouring the net have the same pin hole:
I am not able to find one that is drilled all the way through like yours. What gives?
->Mark
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Mark, I have several sets I consider original and 1 set doesn't have any holes in the bottom, another a small hole and a third set like in my pictures from before with the larger hole. I can't say any of these are wrong as all are the correct size and shape and material and hold a wing wire in place and have a rubber o-ring between the Lexan wing and the screw on top.
This is all very interesting!
- duckhead
This is likely an artifact then of them being small and hand machined / drilled / tapped. Curious what the intended design was, no hole, or through hole? I'd argue the small hole was NOT the intended outcomea01butal wrote: ↑Tue Sep 29, 2020 7:33 am Mark, I have several sets I consider original and 1 set doesn't have any holes in the bottom, another a small hole and a third set like in my pictures from before with the larger hole. I can't say any of these are wrong as all are the correct size and shape and material and hold a wing wire in place and have a rubber o-ring between the Lexan wing and the screw on top.
Thanks for looking Al, I appreciate it!
->Mark
- Has thanked: 2759 times
- Been thanked: 2250 times
Yup I'd say its just that the conical tip of the drill bit went fully through but probably unintended .
- 1751 Views
Last post by Eau Rouge
- 1302 Views
Last post by NomadRacer
- 1844 Views
Last post by romulus22
- 966 Views
Last post by CAT3K
- 1814 Views
Last post by PBR Allstar
- 522 Views
Last post by Dr. Robotnik
- 338 Views
Last post by Brandon G
- 938 Views
Last post by mytimac
