kyosho lazer zx late edition?
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Re: kyosho lazer zx late edition?
Post by EvolutionRevolution »
Kyosho Fan2 wrote: (even though the hubs were a down grade) so its a bit special.
Why are the plastic hubs considered a downgrade? The plastic versions have a considerably better fit than the cast alloy ones.
isobarik
Been thanked: 10 times
Post by isobarik »
crusaderlyf wrote:the lazer zx was releasted in 1989,I got the one NIB is first edition, ball diff center drive, gear diff, two pieces upper deck.
but the kit come with the zxr wheel and tires.
2.2 W-5026 W-5027 yellow wheels set packed as ZX-3
W-5631M & W-5641M tires
the ZX-5 pack come with the steering plate look like the zxr
ZX-7 pack knuckle arm OT-16 is plastics
Cool never seen that before clearly just between the zx and the zxr.
mvh Isobarik
isobarik
Post by isobarik »
USA-1 wrote:I own a few Lazer's. I bought a ZXR when they 1st came out, was this one a special?
Looking good rather heavy modified lazer ther Law-3 lower chassi, motorplate, shocktowers
i would guess aftermarket upperdeck later years due its rather glossy.
mvh Isobarik
isobarik
Post by isobarik »
thanks for that helpful info, but I think zxr MKII still come with the zxr slipper, hyperclutch only equiped at three cars:zxrr、zx-s & zx-s evolution。[/quote]
MKII came with the hyperclutch basicly its an rip off from the associated one just the slipper pad is on the other side compared to the associated one when you compare the two you know what i mean. The slipper pad has the same diameter as the associated one and it fitts i use them since they are way cheaper.
MKII and the ZXR-R has an slipper plate on theire hyperclutch that uses the standard kyosho spur LA-2 88 tooth modul 0.6 or TM-17 48p 100 tooth in case any want to know.
ZXS and ZXS-evo uses an special slipper plate LA-118 actually it has different numbers also but they are regarding material quality they have standard associated fitting regarding the distance between the screws that hold the spur on and an sleeve over the bearing to center the spur.
mvh Isobarik
Kyosho Fan2
Post by Kyosho Fan2 »
Iso, the mk2 last few did have hypers then the rr was released.
MK2 came originally with the pads but strangley the later ones had hyper clutches then the RR came out most possibly due to Jamie Booth winning the nats and Ellis winning the Euros.
Kyosho Fan2
Try breaking the alloy one and you will see why its a downgrade, also the benefits are the threadlock does its job and keeps the king pins in whereas the plastic ones had a tendancy to vibrate the king pins out and due to that damage the thread in the plastic meaning a replacement. Also the alloy zx ones you do not need to cut the lobes off to stop the bumpsteer. The only downside is having to file the arm or wishbone a bit to account for more steering that the plastic one gives. Also If you screw the king pins in correctly and make sure that they are equal on both sides its a perfect fit, mind you I do prefer the team line hubs and they are much more a perfect fit.
Kyosho Fan2
crusaderlyf wrote:
Kyosho Fan2 wrote:thanks for that helpful info, but I think zxr MKII still come with the zxr slipper, hyperclutch only equiped at three cars:zxrr、zx-s & zx-s evolution。
possible,but I checked all the label like zx-5 zx-7 their pack never been opened.but as say I still can change the original mint parts back it turn to the first kit. :D
Was the box opened or did it have the seal on it, as the only explanation is that if the seal was broken then some items were removed or that this kit originally had items missing so they either replaced the missing items with the later parts etc etc. did it come direct from a shop or a thrid party collector? Still as it came with all that in the kit (if from a supplier) its a rarity so makes it that little bit more special. Twenty two years on and I am still racing mine.
crusaderlyf
Post by crusaderlyf »
So I got the zxr kit NIB is the one before the rr released, it comes the zxr pads slipper.
isobarik
Post by isobarik »
crusaderlyf wrote:So I got the zxr kit NIB is the one before the rr released, it comes the zxr pads slipper.
Is youre kit an ZXR or an ZXR MKII since the first has the clamp the spur slipper and the later has the hyperclutch.
mvh isobarik
USA-1
Post by USA-1 »
mvh Isobarik
Thanks, The upper deck is a fiberlyte I do have the original 2 piece.
I found this on another site, apparently this car was a proto type that went into production.
The LEGEND car of Rick Hohwart from Peak Performance at the WC 89 in Australia.
The LEGEND is the prototype car for this race, products and built by Kyosho for his team around the World.
The production name is LAZER ZX...
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
Man, I'd love a set of those shock towers. Heck, I'd build a shelfer just to show them off!!! :mrgreen: :mrgreen:
isobarik
Post by isobarik »
mvh Isobarik
Sure is did you bought it like that ??? seems like very little use on the shocktowers to.
If, it seams like someone tried to build an legend.
mvh Isobarik
Jirka
Has thanked: 33 times
Been thanked: 24 times
Post by Jirka »
isobarik wrote:
USA-1 wrote: The LEGEND car of Rick Hohwart from Peak Performance at the WC 89 in Australia.
mvh Isobarik
prp did this Rick Howart's Legend replica some time ago: http://www.rc10talk.com/viewtopic.php?f=30&t=16922
Jirka
USA-1
Post by USA-1 »
mvh Isobarik
Hi I actually bought it like this, this came up on Ebay about a year ago and the guy selling it said it was some kind of special I didn't pay much attention I just thought it was a neat looking Lazer having never seen one done in CF and those shock towers.
I don't know if it was ever use the front bumper was like new I put it on my ZXR. :D
Kyosho Fan2
I had those shock towers, only downside was if you crashed they would snap but never the less were very useful.
Return to “Kyosho Forum”
Users browsing this forum: User avatarRichieRich and 6 guests
