the one from a 7077 conversion kit is the same. the one for the ultra molded chassis is different, although the 10t bulkhead will work on that, too.Erich Reichert wrote:ok, rookie question here. Is the world front bulkhead narrower then the 10t part or are they basically the same? Thanks!
Anyone know what version this is?
- Has thanked: 36 times
- Been thanked: 1318 times
- Erich Reichert
yup, that would be correct. plus, if you have the top plate for the c.c. worlds chassis, you have to use the 10t bulkhead because of mounting the spreader bar that the top plate attaches to.Erich Reichert wrote:Reason I ask is bc I want to know which will fit on my Comp Craft Worlds chassis (narrow nose) too. I actually ended up coming across the standard width rpm bulkhead last night for my tub chassis so your saying I can use a truck bulkhead on my Comp chassis?
- Attachments
- IMG_2178.JPG (143.67 KiB) Viewed 559 times
- Erich Reichert
NICE! I'm not sure if mine have a bar though... does it come with the chassis? Mine are both (I actually have two) new in the package but I don't remember seeing anything other then plates. One is both plates in one bag and the other is plates in seperate bags (replacements maybe). Is that bar just like a nose brace with holes drilled in it? If I don't have one I can prob just make it. Thanks for the pic... it was a HUGE help.
- 800 Views
- 980 Views
Last post by TRX-1-3
- 902 Views
Last post by RC10resto
- 955 Views
Last post by Brandon G
- 21 Replies
- 1720 Views
Last post by treehugger
- 1323 Views
Last post by jcwrks
- 1326 Views
Last post by rc-stu
- 1150 Views
Last post by AscotConversion
