Talking of belts...
crusaderlyf
Re: Talking of belts...
Post by crusaderlyf »
Mad Racer wrote:I/ve used him before and his prices are really good.
As for the belts im still not sure as my belts are slipping on my Lazer Zx but not sure if it's the belts, or pulleys..
lazer belt easy to find than others
figured I'd show you guys my new and spiffy belt cutting capability. I picked up 9mm belts from SDP-SI as I mentioned earlier, which we all know are too wide.
So I figured when they cut belts to width, all they have to be doing is jigging a cutting blade so that the blade will cleanly slice the belt in two. Since I got my lathe up and running, I wheeled up a couple 'pulleys' out of some scrap material, along with an idler arm and axle to attach to my carriage stop/indicator bracket. Then I made a razor blade attachment for my quick change toolpost.
the results speak for themselves 8)
Has thanked: 359 times
Been thanked: 471 times
Damn, thats pretty snazzy!!
oh, since the belts are pretty fragile when subject to a sharp implement like a razor blade, I left the lathe in neutral(belt tension off) and just spun the chuck by hand to take it slow and easy. no sense in turning a brand new belt into shreds in an instant if something is awry.....
xxxmain
Post by xxxmain »
Awesome!! Great job on the belt cutting tool!!!
oh, and the black 'washer' looking thing on the idler pulley is an old servo horn that worked perfectly to keep the belt from rolling off the pulley. The indicator clamp is all hand made(the part holding the idler arm to the lathe bed), and as such, it's off a tiny bit, making the belt want to wander off the idler.
GJW
Post by GJW »
thats wicked mate, bet no one else has one of these 8)
Seabass
Business Member
Post by Seabass »
Dude that is absolutely awesome. Great thinking there man.
BTW I got one of these belts and I must say you cannot tell the belt was cut and it looks perfect in every way.
Excellent work man.
Jake
Return to “Yokomo Forum”
