don't you just hate.....
treehugger
Re: don't you just hate.....
Post by treehugger »
scr8p wrote:ya, i'm gonna keep it open for awhile to air out......... and make sure there's not gonna be a round 3. :roll:
everything's back together back together now and seems to be ok. but, i thought that last night too.
pretty sure the problem was that the torch was too small. big enough to do 1/2" pipe, but not 3/4". maybe it's just too old and not working properly. you had to put heat on the fitting for way too long before the solder would melt. in the meantime, burning off all of the flux. so, it didn't get a good solid solder joint. my dad stopped at the hardware store and got me the "binford 5000" :lol: of propane torches to do it this time. it worked much better. so, fingers crossed.
Having worked on all sorts of jobs along side plumbers h vac i learned that the only gas for sweating pipes is a mix Map gas (yellow can not blue ) the acetelean mixed with the propane means the fitting heats up FAST so saving your flux
good luck
Paul
oh and fyi when you sweat water pipes ( hot cold ) you must run the lines for about 10 mins to flush the flux out
Has thanked: 3699 times
Been thanked: 1980 times
treehugger wrote: i learned that the only gas for sweating pipes is
...a bad chili dog at 3 a.m.?? :lol:
treehugger
oh yes i wish thumbs cant find any on this side of the pond ,chille ,curry , i will be bringing back a good supply of vindaloos curry powder when i go home in april :wink:
Paul
