$20 ebay beater + homemade 4wd kit
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
What...like you're some kind of lexan expert or something?mrlexan wrote:Careful with brake fluid. If you leave it soaking for any extended period of time, it breaks down the lexan and it will spider crack almost like glass. I personally won't use it.
Jay
I agree, I won't use it either. Just too much work especially with proper disposal.
- Volumiza
you mean i risked my only two bodies???? . i've come over all queasymrlexan wrote:Careful with brake fluid. If you leave it soaking for any extended period of time, it breaks down the lexan and it will spider crack almost like glass. I personally won't use it.
Jay
where were you two when i was asking the same?
luckily it turned out okay.
"I want to die peacefully in my sleep like my grandfather, not screaming in terror like his passengers!" The late great Bob Monkhouse 1928 - 2003.
- mrlexan
- Been thanked: 10 times
Cloudy is not a bad thing..... remember when you paint bodies the general rule to promote adhesion is to scuff up the to be painted surface.... this of course doesn't apply to windows that are trying to be keep clear, but you could always dust those.
The one factor that seems to influence everything and you can't do anything about... is the exact make up or grade of lexan/polycarb used. Seems different thing act differently to diff manuf bodies.
BOTTOM LINE..... it is a crap shoot.
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
I have had this happen and I think this has to do with the paint. If the paint was good in the first place, it should have etched into the lexan a bit. I think the cloudyness you see is the paint etching.tomstacey wrote:I've found nitro fuel made a body I had go cloudy.. maybe the brand makes a difference?
- Erich Reichert
Ok, boys and girls I rmeember what it was. The stuff I used to clean paint off was Testors Brush Cleaner. Its a glass bottle with an orange label and the liquid is clear. You pretty much just wipe it on with a rag and it makes the paint orange peel up and then you just wipe it away. It doesn't do anything to the lexan either which is a bonus!
http://www.misterart.com/g43/Testors-Brush-Cleaner-for-Enamels.htm?WT.mc_n=nextag&WT.mc_t=CPC&WT.mc_id=43
- Volumiza
but wont that affect the clarity of the colour when it's painted?mrlexan wrote:Cloudy is not a bad thing..... remember when you paint bodies the general rule to promote adhesion is to scuff up the to be painted surface ...
- Volumiza
i was going to try and spray my newly stripped body today so i'll give it a go, thanks.mrlexan wrote:volumiza.... no it won't when you paint over the cloudy ness, it just goes to color. As mentioned, some (not all) paints suggest that you scuff by the inside of the body with sandpaper prior to paint. Try it out one time.
- Dr. Robotnik
Re: $20 ebay beater
I have stripped the car down again to fit some white parts I have obtained in lots recently and also in preparation for the incoming Protech body...
I have also been making a whole bunch of the box art cars parts like the GRP front and rear shock towers, rear transmission brace, battery straps, nylon spring cups, etc...
- templeofspeed
Re: $20 ebay beater
Yay! Are you going to require provenance for those who might wish to obtain these items?Dr. Robotnik wrote:
- 2033 Views
Last post by Dr. Robotnik
- 28 Replies
- 3412 Views
- 818 Views
Last post by Asso_man!
- 106 Replies
- 11989 Views
Last post by Mr. ED
- 1588 Views
Last post by clodsrule
- 35 Replies
- 5194 Views
Last post by AscotConversion
- 787 Views
Last post by a01butal
- 24 Replies
- 2654 Views
Last post by Bormac
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Majestic-12 [Bot], Tbot [Bot] and 41 guests
