Fibre-lyte Graphite Buggy
Kyosho Fan2
Re: Fibre-lyte Graphite Buggy
Post by Kyosho Fan2 »
Fibre-Lyte still do all these parts, so just look on their website and buy buy buy. The actual weave is better than the kits spec so youll get a stronger chassis that can take a beating. Worth every penny. I designed the first tub chassis for the Lazer ZX and used it for ten years with zero tape on the underneath and the chassis still looked good considering I used it three times a week. You wont be sorry with them.
flipwils11
Been thanked: 19 times
Post by flipwils11 »
railey72 wrote:Here is the start of my next build. I have been acquiring parts for about a year and finally got everything together. Picked up the correct drill bits and countersinks to do the front end and hope to start on the chassis sometime next week. Apparently they no longer have the template to drill the front end so it comes un-drilled. The Fibre-Lyte tub is really a thing of beauty. Those guys make some nice looking parts.
Holy hell, Doug this is pretty insane. Ooof!! :shock: Those Tecnacraft wheels!!
aeiou
Post by aeiou »
This is going to be a sweet one. :wink:
Good luck with the nose piece.
greazy
Post by greazy »
Cant wait to see this together , it will be the Barrett - Jackson of RC10.
call-911
Post by call-911 »
Looks like it will be an AWESOME ride.
Total cost of this ride?
1 million dollars!
Keith C
railey72
Post by railey72 »
Hope everyone had a great Holiday Weekend!
Got a little work done on the chassis. Drilling the nose piece ended up being a pretty easy job. I was a little worried about how the weave would react to a countersink bit but that wasn't an issue. So far it looks like everything is straight and bolting together well.
slow_jun
Post by slow_jun »
This project will make any of mine a mere puny.... :oops:
I was trying to look for Adjective to describe this build
and Google came up with this. -prodigious-
Cant wait for the finish product.
Happy New Year!!!!
-jun
― Confucius
Kyosho Fan2
Word of advice with the holes you have drilled. Take out the screws and put some glue around the areas that you have countersunk, only enough to cover the cut that you have made. When dried then screw all together again This strengthens it as without you may get a split if your racing it.
drbelleville
Post by drbelleville »
[quote="railey72"]Hope everyone had a great Holiday Weekend!
quote]
I wanted to ask about your counter sink you used, do you have any information. I had used a couple from Snap-on, and have managed to mangle a few. Its been hit or miss, now I have switched to a TiNi Bosch Countersink.
Regards,
Maurice
that is an awesome buggy!
You have to use a real countersink, for metal. One designed for use on wood, or the typical stuff you would find at home depot or lowes, doesn't stand a chance......
mcmaster-carr carries them, any industrial supply house, grainger, msc, fastenal, etc etc.
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
Carbide right?
carbide is recommended if doing full speed machining operations with carbon fiber.....hss or any other standard coated part would work fine for the small number of holes you would expect to do by hand.
nsr250_repsol
Post by nsr250_repsol »
Just received my Fiber-Lyte parts in the mail today :shock: When they say the nose is undrilled they mean completely undrilled. I will need to get the right bits and countersink bits soon. I'm still waiting my storage shipment from my PCS to come in before I can start my build; my MIP 4-10L converted Team Car is in that shipment. I don't have the swank Tecnacraft wheels though :( Probibly never will with the prices they have been getting for them on ebay recently....
eBay ID: Nsr250_sp_repsol
railey72
Post by railey72 »
drbelleville wrote: I wanted to ask about your counter sink you used, do you have any information. I had used a couple from Snap-on, and have managed to mangle a few. Its been hit or miss, now I have switched to a TiNi Bosch Countersink.
I used a 100 degree carbide single flute countersink and didn't have any issues. That's a good idea about gluing the countersink cut. Should certainly strengthen the holes.
Here is the stealth mocked up with the graphite motor plate. It was either this plate or a litespeed plate but I think this one looks better with the chassis.
shodog
Been thanked: 91 times
Post by shodog »
Whoa, where did you get the sweet aluminum stealth case?
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarSeznam [Bot] and 4 guests
