Finman's RC10 Graphite(?)
PBR Allstar
Re: Finman's RC10 Graphite(?)
Post by PBR Allstar »
once the nylon strips it's kind of done, the one thing you can do that will help out in a pinch is putting a dab of CA on the fastener, just be careful not to get it everywhere, like for instance if you're mounting some of your fiber lyte parts, don't want CA drips down any of the carbon!
RedScampi
Post by RedScampi »
Put some ca glue in the holes and run the screw in. Take it out before it sets completely.
Gary
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
if possible tap them for the next diameter screws available. By tapping the tread beforehand you put less stress than by just putting in a larger screw.
SteveK
Post by SteveK »
Agreed, the next largest screw would be the most secure way to mount them, but I've found using a cutting tap makes the holes feel loose as well (like threading it into a metal nut). Unless the hole is so tight you can't get the screw in, letting the screw cut it's own threads will work OK in soft plastic like this.
Has thanked: 358 times
Been thanked: 470 times
M3 pitch Metric fills the space nicely w/o tapping :P
SteveK
Post by SteveK »
I figured that was the case, but I wasn't sure; I was looking up the drill sizes and I can't do the math in my head right now LOL
Mr. ED
Post by Mr. ED »
SteveK wrote:Agreed, the next largest screw would be the most secure way to mount them, but I've found using a cutting tap makes the holes feel loose as well (like threading it into a metal nut). Unless the hole is so tight you can't get the screw in, letting the screw cut it's own threads will work OK in soft plastic like this.
I've got 3 taps in my kit: different stages of finish. For plastic I only use upto the 2nd for the above reason.
finman
Has thanked: 4 times
Post by finman »
A bit of a thread resurrection here, I think I may be competing with Scr8p for completing projects.
I know being in the UK can slow these projects down but nearly three years :lol: .
Just had the body done for this car, thanks to Percymon for the link
Should get on and finish it off now!!
Rich
And this is how it starts
Users browsing this forum: No User AvatarGoogle [Bot] and 12 guests
