turns out i did ruin a few of the rpm cups, threaded right through them when i was adjusting the rods.
i have a set of white jconcepts on order now.
i held them up to the stockers and they are the same length.justinspeed79 wrote:RPM arms make no difference. Are you sure you didn't get the GT2 set? Sounds obvious, but if you just look at the label quickly it would be an easy mistake to make. Maybe they were mis-labeled???
