Reaming the 3mm holes by .2mm would make them a good fit for 1/8" hingepins , no need for brass tubingjwscab wrote:the only other thing you can do to reduce slop is to ream out the hing pin holes and press in brass tubing, then ream to the desired clearance(if needed). I have done this in some nylon parts, and the hinge pins were 1/8". I used 5/32" tubing. I think the yok stuff is all 3mm though....so you would need to find appropriate tubing.
Prepping a 870C runner - questions and progress.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Prepping a 870C runner - questions and progress.
- Been thanked: 498 times
moving from 3mm to 1/8" is a simple and effective plan......if you are comfortable with that.
but moving to the tubing moves the wear points to easily replaceable parts.....the hard stuff to find won't wear out unless you physically break it.
and the stuff i did was already 1/8", so I couldn't ream oversize.....
- Mr. ED
oooh, I just remember another trick: drill a little hole in the magnesium part, tap it, and put a set screw on the hingepin. now the only part which can develop slop is the arm itself.
By the way removing slop can make a car really twitchy and hard to keep going straight. Maybe it's better to try it first = as is.
- Been thanked: 10 times
thanks for all the helpful replies as always guys! I decided to go with the turnbuckle route and that helped significantly!
I'm amazed at how much steering angle this car has!
Finally my 870C is ready to run at the upcoming event. Here are some pics!
Basher shell that the original used car came with... (Parma Eagle?)
Without shell...
Fresh paint in BC's standard red, blue and yellow!
More on my blog...
Without shell...
More on my blog...
- Mr. ED
It's an Andy's apache warrior shell actually. Both look good with those paintschemes
- Seabass
- Business Member
- Been thanked: 12 times
The yoke looks very nice. What kind of mill are using running to mill your CF? I have some plans to do quite a bit of CF work on a couple cars I am getting ready to build.
Jake
Jake
I normally use a 4mm carbide end mill on a Sherline 5410 mill.
You'll love those Caliber tires too, I have some and they are my "everywhere" tire, they last forever too! street, grass, dirt. good choice for an oldie runner
Mark
- Bormac
- Has thanked: 21 times
- Been thanked: 11 times
Well done on your 870c dude! These are awesome vintage buggies and it should get people turning heads when you hit the track. Performance wise this car is no slouch either.
Good to see another 870c hit the dirt.
Thanks bormac! Here is the car hitting the dirt for the first time since my restoration!
[youtube]997VWjnAMxs[/youtube]
markt311 - absolutely agree on the calibers. I find they are a tad lacking in side bite on our track but they offer good performance and outstanding wear rates so they are my current choice for regular runner tires.
Car's performance is amazing!
Just sharing another run of the car with some other vintage buggies.
[youtube]n4vFdSuQpDY[/youtube]
- GJW
very nice build, love the carbon look on the 870c. cool vids, cheers for the upload.
Beautiful build you have there. Did you machine the alum. posts for the battery straps also?
- 2331 Views
Last post by 59burst
- 2450 Views
Last post by scoobyrs25
- 26 Replies
- 5760 Views
Last post by caesar
- 2730 Views
- 943 Views
Last post by uzzi
- 2820 Views
Last post by ChicagoRC10T
- 939 Views
Last post by tiger1
- 2477 Views
Last post by 250r
