I'm waiting on the graphite front shock tower from aeiou that I need, and then the body is underway for paintwork now.
Project Unnecessary Metal: Shelfer Build
- flipwils11
- Been thanked: 19 times
Re: Project Unnecessary Metal: Shelfer Build
This CE I picked up today is donating its shocks to the project. I have used the spring perches and collars from bigjeepz and had them anno'd. I was a bit disappointed that the graphite trans brace I got won't work on the MIP trans because it wants to have even spacing on the four holes like a 6 gear trans brace. If someone has another black graphite trans brace in mind that I should look for, let me know.
why dont you use a piece of alloy as trans brace it would look different than the normal always got go CF route ?you could use a piece of old chassis annoed goldflipwils11 wrote: I was a bit disappointed that the graphite trans brace I got won't work on the MIP trans because it wants to have even spacing on the four holes like a 6 gear trans brace. If someone has another black graphite trans brace in mind that I should look for, let me know
Paul
Wow, this project is looking amazing! It'd almost be a shame to cover this car with a body.
Gary
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
I hope those aren't black PLASTIC shock caps! Please tell me they are the black metal ones...you know, to go along with the theam
- flipwils11
Sadly, yes because they came from the CE I got locally. I would prefer metal but I like the black top contrast. Did they make black metal caps?vintage AE wrote:I hope those aren't black PLASTIC shock caps! Please tell me they are the black metal ones...you know, to go along with the theam
- flipwils11
Forgot to comment about this earlier in this thread, but changed the tie rods from the Lunsford direction in the first post to Tecnacraft. Some of you may have seen a few weeks ago that a lot of them came up on ebay from a seller so I snagged some in varying lengths. I liked that better to preserve the vintage new old stock parts aspect of this build.
Now it's time to find the right motor, put in the NIB Tekin ESC, and radio. The body is nearing completion on the paint I think, but I will need to sort out decals.
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Nice Adam! Someday this winter you should try fabbing a set of (murderous for running) metal spiked tires done in gold. For a shelfer in Mn that would be cool to see
That has to be one of the best looking RC10's that I have ever seen. Some nice carbon fiber parts would put it over the top. Great build.
- ChicagoRC10T
Wow! That looks spectacular. I especially like the wheels.
It seems like you purposely avoided factory blue parts where possible... except for the 8-32 countersunk screws for the steering links. I did a similar build (though not as nice as yours) using the Atlas steering links and looked everywhere for black or gold screws that were long enough. I ended up installing the sleeves upside down (eliminating the need for the nut). Doing this, you can get away with the shorter gold screws that are still available, adding more gold to this impressive car.
Nice looking buggy. I am wondering what the difference in weight is between the nylon parts that you replaced with aluminum. Definitely cool!
- flipwils11
Wow, that sounds like a challenge... but I think I'm near the end on this one. It was a major undertaking right out of the gate for my first project.Y'ernat Al wrote:Nice Adam! Someday this winter you should try fabbing a set of (murderous for running) metal spiked tires done in gold. For a shelfer in Mn that would be cool to see![]()
thanks! But I'm not really feeling the carbon at least with this build. That's why I went for the graphite shock towers since they seemed closest to a metal theme than carbon fiber or fiberglass.xanadu wrote:That has to be one of the best looking RC10's that I have ever seen. Some nice carbon fiber parts would put it over the top. Great build.
Thanks, I like the wheels as well even though they're more orangy than the rest of the car. Good idea on the Atlas sleeves but I guess I'll leave it as-is. I like the black nuts, but you're correct, I wasn't pleased when the screws arrived from Tower and they were blue!ChicagoRC10T wrote:Wow! That looks spectacular. I especially like the wheels.
I can't stop staring at it on my workbench, and there's more to come when you guys see the body. The titanium stuff definitely feels feather light such as the hinge pins where I think could tell a difference. It feels like a tank though and there's no motor, electronics, or battery yet!allaircooled wrote:Nice looking buggy. I am wondering what the difference in weight is between the nylon parts that you replaced with aluminum. Definitely cool!
- Seabass
- Business Member
- Been thanked: 12 times
Man this build turned out really nice. I like the result and I know this was not easy on the wallet. Looks good and will fit on the shelf nicely.
Jake
Jake
- 2342 Views
Last post by THEYTOOKMYTHUMB
- 164 Replies
- 18943 Views
Last post by Bakauata
- 1447 Views
Last post by marlo
- 23 Replies
- 2094 Views
Last post by jon burrows
- 857 Views
Last post by klavy69
- 912 Views
- 1270 Views
Last post by yellabelly
- 95 Replies
- 9801 Views
Last post by Tadracket
DotNetDotCom.org [Bot],
Mojeek [Bot] and 5 guests
