Oval 10LSS build, Paint is done
Seabass
Business Member
Re: On road VONATS build (if it happens this year)
Post by Seabass »
Thanks for the input on the car. I am one of the most ignorant people when it comes to the pan cars.
I really appreciate the info on the chassis, it will help me decide which one to use. The axles are already done, so there is no turning back now, LOL. I never thought about the shims that go into the front and didn't take that in account when I made the brace. That can easily be changed. I also did realize the links would end up dropping as far down as they do at full lock.
As far as my machine goes, I don't have enough travel in my z axis (up and down) to fit the tool, 3 jaw chauck, and rotary table. The unfortunate thing is they don't make chucks much shorter than the 3 jaw I already have and if there was a shorter one, it may not have the capacity to hold the wheel.
I am also working on something else for this car but I am too far away from getting it completed to discuss it here. I will show you guys what I am working on when it gets closer to completion.
Jake
Eau Rouge
Post by Eau Rouge »
Good deal. If you need any help, I have raced 1/12th carpet road and 1/10th superspeedway cars since the late 80s, and there isn't too much new under the sun. Just send along a PM if you have any other questions. I might even have parts in the bins if you need something special.
Seabass
Business Member
Post by Seabass »
Ok great thank for the help.
In fact sending PM to you in a sec.
Seabass
Business Member
Post by Seabass »
I have been collecting parts for this car and took a pretty big break from working on it. I finally got most of the car together but still have a few minor things to do. I ended up machining some new axles for the front to bring the front tires out roughly 1/4 inch. The outside edge of the front tires are now even with the outer edge of the rear tires.
I installed an IRS rear axle on the car and I beleive and HPI bottom pod brace witha small kick up and a Composite Craft upper pod brace.
After consulting with the experts the front brace I made has been removed from the car. I am going to machine another brace that will not interfere with the castor in the front of the car.
I have a body on the way to the house so hopefully I can call this one done in the next week or two. Now I need to find some oval races so I can join in the fun.
drbelleville
Re: Oval 10LSS build, No vonats this year :(
Post by drbelleville »
Nice GE car :) Are those IRS hubs too?
Seabass
Business Member
Post by Seabass »
I have an IRS hub on the right. The left side has the standard 10L hub. I need to find a left IRS hub to match.
The car is turning out nice, Just a tad more to go. Then comes tuning questions for a basic setup to start with.
Jake
Popps 59
Post by Popps 59 »
The front axles are cool and will not hurt anything, however most pan car racers run 1/8th axles cause the balls are bigger and last longer/suffer damage less often. Love the machine work you're doing.
Seabass
Business Member
Post by Seabass »
Thanks for the compliments. This one is almost done.
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
nice car jake! It's good to have the experienced guys on board when building cars you are not familiar with that's for sure.
m_vice
Post by m_vice »
Jake , i have a new bumper for this one i have to clean up the place and get it all together. :D
Seabass
Business Member
Re: Oval 10LSS build, Paint is done
Post by Seabass »
I got the body painted and partially mounted.
I decided to go with my own Nascar theme on this one. I found the Rockstar decals on eBay from a drift car. Did some modifying of the decals to work on this car. I still need to find some numbers and buy some fender decals to make it look the part. Like an idiot, I should have drilled my body post holes before paint. It is very difficult getting the body to line up with the wheel wells. I need to do some more trimming.
I also machined some posts for the rear support. I still have a few other things to do to the car including machining a new front brace for the front suspension. I am waiting for the material to arrive. Other than that I think the car is ready for electronics.
I hope to run some laps with the car around Christmas time. Going home for the holidays where there is an onroad and oval track.
Jake
Has thanked: 3699 times
Been thanked: 1980 times
I think it just moved.......... :shock:
:lol: Seriously, very nice! :mrgreen:
railey72
Post by railey72 »
Jake,
Awesome build. Love the CC chassis along with the IRS stuff.
What wheels are those?
Users browsing this forum: No User AvatarSeznam [Bot] and 5 guests
