It's not a paint, it's a dye, only in spray form. It requires no primer (as paint does) and bonds to the plastic, just as Pactra paint bonds to Lexan. It works great on most plastics and vinyl, I've used it to restore my Charger's interior. If you give it the full week to cure properly, it's not supposed to even scratch or chip off. What did you use it on, Monokote?clhuke64 wrote:Krylon Fusion is a paint not a dye- I tried it on a RC Airplane body - all it did was flake off after it dryed. I guess it only works on certain plastics !!
Dylon Dye Products
- Been thanked: 325 times
Re: Dylon Dye Products
I painted the body of my firebird (airplane, witch has a plastic body) and flaked off the next day !!! When it flaked off like regular Krylon paint, made me think that it is a paint product.
Maybe you prepped the surface differently...it suggests to make sure the surface is clean, I even used acetone to clean my interior console parts, and Simple Green to clean the vinyl parts, and rubbing alcohol to clean the nylon front bumper (aftermarket) for my Optima. In all those cases, the Krylon Fusion has adhered exceptionally well, and indeed appears to have bonded to the substrate beneath. Each of those had a week to cure, per the can's directions. If it was flaking off after only one day, maybe there was grease or something on the surface?clhuke64 wrote:I painted the body of my firebird (airplane, witch has a plastic body) and flaked off the next day !!! When it flaked off like regular Krylon paint, made me think that it is a paint product.
Here are some pictures of how nicely the semi-gloss black Krylon Fusion worked on my interior parts (the grimy, grubby white parts are the "before" shots). Spray paint wouldn't stick to flexible vinyl at all, which is why Krylon Fusion is a completely different animal than just rattle-can spray paint.
http://img822.yfrog.com/gal.php?g=tearrepair3.jpg
Check out the plastic console, which was faded black and I mated a burgundy end-piece to fix the original cracked black end-piece, and the vinyl door panels.
- 827 Views
Last post by RedScampi
- 1704 Views
Last post by mikedealer
- 2930 Views
Last post by qctires
- 2041 Views
Last post by Synergy
- 490 Views
Last post by ROH73
- 1464 Views
Last post by shodog
- 641 Views
Last post by THE H.P FREAK
- 1423 Views
Last post by Mr. ED
Users browsing this forum: DramaSteveMc,
Dustydrone,
Google Adsense [Bot],
tommy911t and 8 guests
